1988 Dodge 318 dual exhuast problem
2 Attachment(s)
I have a 1988 dodge 318 4 speed manual 4x4 truck that I have just installed headers on and, Im having a little bit of trouble figuring out a problem. On the driver side cross member there is a vaccum ball of some sort that is in the way of my exhuast pipe I need to run.
What I would like to know is can I move it to a different spot and hang it out of the way so I can Run my pipe threw Here are some pictures that may make it make a little more sense. Thanks for all replys and help Its appreciated Ed |
That's the vacuum canister for the shift-on-the-fly transfer case. You could probably relocate it if you splice the vacuum lines.
| All times are GMT -7. The time now is 05:21 AM. |
