2006 2500 5.7 weird code?
Old Feb 15, 2012 | 01:38 PM
Daniel Albert's Avatar
I keep getting this code that I can not figure out. Its P0004. Doesnt show up on any list that I have looked at. Any ideas? Check engine light comes on but its running well.
Old Feb 15, 2012 | 06:23 PM
scotts74birds's Avatar
What did you scan it with? I have heard about this code from people using a Harbor Freight scanner.
Old Feb 16, 2012 | 03:22 AM
This is what I found.
P0004 - Fuel Volume Regulator Control Circuit High
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
Tech notes
The P0004 is an OBDII generic code, but almost none of the vehicle manufactures use it. If you are getting this code, make sure you are using the correct OBDII code scanner for your vehicle's make and model.
P0004 Description
Fuel Volume Regulator Control Circuit High is the generic definition for the P0004; however your vehicle's manufacturer may have a different definition for the P0004 code.
Old Feb 16, 2012 | 05:11 AM
I did clear the code and this morning came up with this p0420, catalyst efficiency.
I did just replace both manifolds (exhaust) and all 4 O2s a week ago. Cleaned throttle plate and intake. Runs great! Just trying to pinpoint the codes that are coming up. Bad cat or maybe software in the engine controller? Who knows.
Old Feb 17, 2012 | 03:44 AM
Still No code today.
Old Feb 18, 2012 | 03:53 PM
Got the P0420 code again
Old Jul 21, 2012 | 07:22 PM
levi's Avatar
P0004 -
I've pulled this code off my truck. And found a lot of info. On what it is. But having a hard time. locating any info. On how to fix
parrothead6970
Feb 17, 2011 07:14 AM
puller
Oct 8, 2010 03:41 AM
CantRamItDodgeIt91
Sep 27, 2010 10:34 PM
gary2010
Jan 14, 2010 08:26 PM
BigPaddle
Nov 23, 2009 09:01 PM
