Mopar Forums (/forums/)
-   94-Current Dodge Trucks (https://moparforums.com/forums/f18/)
-   -   97 Ram falls on face (https://moparforums.com/forums/f18/97-ram-falls-face-7271/)
spacey70 Aug 22, 2010 04:03 PM
My 97 Ram/360 can't seem to get above 2800RPM. If I try to pass on high way it will kick down but as soon as i hit around 4K rpm it falls on its face. New fuel pump and pressure regulator. Any ideas? Is there a TPS on there?
mod381 Aug 22, 2010 04:12 PM
First thing I would check is for plugged cat converter
78D200 Aug 23, 2010 02:40 AM
Yes there is a TPS on throttle body.
I would knock on the cat though and see if you hear anything rattle around like mod381 said.
scotts74birds Aug 24, 2010 03:57 PM
Happened to my 95's cat. Same symptoms.
blue 68 gts Aug 25, 2010 02:27 PM
If it was the cat, wouldn't you be able to hear it breaking up? If it got to the point of making the motor run like crap...
Silverick Aug 25, 2010 03:11 PM
I vote for the cat! We had a shop truck with the same symptom and a new cat did the trick.
