Mopar Forums (/forums/)
-   94-Current Dodge Trucks (https://moparforums.com/forums/f18/)
-   -   Engine Rebuild Kit (https://moparforums.com/forums/f18/engine-rebuild-kit-7694/)
Austin The Rat-Rod Kid Oct 5, 2010 09:52 PM
Engine Rebuild Kit
1 Attachment(s)
Looking for same help on finding a kit for a low price online. Today i called around town and got eastimes from 420-2300. I have look on summit but theres got to be cheaper then 325.69.Thanks in advance everyone.
Looking 1999 Dodge Ram 1500 5.9 liter Engine Rebuild Kit
Any help will be greatly appreciated
Thanks
Austin
78D200 Oct 6, 2010 02:21 AM
It all depends on how far you want to tear into the motor and "rebuild it". You can just tear it apart and replace the gaskets and some bearings, all that and rings, all that and pistons plus cam, etc.. Also are you going to be doing this yourself or have an engine shop do it for you?
Austin The Rat-Rod Kid Oct 6, 2010 05:29 PM
Will right now the top half is apart. The engine has like 200 000 miles on. So it makes sense to do it no then let. No ponit of doing it half ass right? Thoses estimates where just for rebuild kits I was thinking of doing it myself.
78D200 Oct 6, 2010 07:29 PM
I saw that the ones from Summit were listed only up to 1996. I don't think there was any difference in Magnum motors though from 1996 and 1999.
Intake and plentum gaskets, head/valve cover gaskets and rebuild the heads. If the block is out, you might as well replace all the bearings and rings. Look into Jeggs as well. I'm not sure who else sells Magnum rebuild kits but I'm sure if you Google it and look under "shopping" you'll find some.
daisyjohn Nov 22, 2013 01:52 AM
Any small engine shop can supply you the parts. Look up in your area .
TVLynn Nov 22, 2013 09:54 AM
Your 20 years behind the times !!!! Parts have got expensive. I have never had good luck replacing rings without a rebore
ZEN357 Mar 16, 2018 05:16 AM
Why now just get a remanufactured engine from Jasper Engines and then core your old motor back to them?
