exterior lighting
Guest
Posts: n/a
I have an 06 Ram 1500 that I have an issue with. For some reason the left front turn signal and head light have stopped working but the bulbs are good, I checked them but there is no power going to the plugs has any one seen this issue?
Guest
Posts: n/a
Thumpn,
Does the headlight come on when you turn the high beams on? It may be a ground problem in that wire loom, or it could be the multifunction switch on the steering column ( aka the turn signal/ high beam switch/ wiper switch ).
I have a `99 Ram 1500 with non-functioning fog lights. It turned out that a shorted power wire to one of the fog lights caused an overload in my multifunction switch, burning a contact.
If the truck is still under warranty, I would just take it to the dealership and let them fix it.
Jonah
Jonah
