loud whineing faster u go louder it gets
08 dodge ram 1500,106,897miles,has loud whinging noise faster u go louder it gets,jack up rear run it ,no sound,checked u joints,checked fluid,gets so loud u can`t talk normal at high speedut like i said,we jacked it up an ran it an no noise,any idea`s ,thinking pinion bearings or wheel bearing ,same tires for 5 years,
My guess would be axle bearing...
If it's a 9 1/4" they're prone to crush sleeve collapse and loose front pinion bearing. Grab the yoke and push up and down hard, that will show you.
Dont over thinkit.
Originally Posted by Bruce Cameron
(Post 143883)
maybe load it with an application of brake, or check the front wheel bearings
