Mopar Forums (/forums/)
-   94-Current Dodge Trucks (https://moparforums.com/forums/f18/)
-   -   Low coolant (https://moparforums.com/forums/f18/low-coolant-16773/)
windsor56 Feb 16, 2014 04:34 PM
Low coolant
I own a 2006 Dodge Ram Mega Cab it has 18000 miles the coolant is red and was wanting to no what to buy to add to it is a little low in the overflow tank Thanks Joe
RacerHog Feb 16, 2014 08:20 PM
Water wont hert it..Or use distilled water...
Dave E Feb 28, 2014 07:25 AM
Yeah just top off with a little distilled water. Although almost any 100,000 mile antifreeze will do as long as it's not Dexcool I believe.
pro-tech Feb 28, 2014 09:15 AM
DONT PUT WATER IN IT...It is to cold around here to add water unless it is only a cup low..Your advice is coming from warm weather guys South and West...Ohio is Cold....Mopar 150,000 mile antifreeze is orange or yellow...If you use Global antifreeze it is compatible with all antifreeze...If you check the label it will tell you...Dex cool is bad and they have a ton of problems with it so stay away from it...In fact if I had a GM car with it I would flush it out and put something else in as we did in the dealership..Bill
fivepoint Feb 28, 2014 03:01 PM
I have been using a premixed 50/50 antifreeze so I don't have to worry about the quality (minerals and iron) in my well water. Yea those California boys don't know what happens to water when it gets down to 15 below zero.
RacerHog Feb 28, 2014 04:26 PM
Hahahahaaahahahahaha...
pro-tech Feb 28, 2014 04:38 PM
Tell him Bob, Ca. has the girls and they are all warmed up...And you can play all year out there at the track...Bill
ZEN357 Mar 14, 2018 05:25 AM
Top it off with anything but dexcool. I usually convert mine over to the old green stuff.
