my gas gauge will not work right
Old Aug 2, 2010 | 12:28 PM
DustinHeck's Avatar
I have a 1990 dodge ram d150 the gas gauge dont work below 1/4 tank and some times it gos to empty what the heck pleas help thanks
Old Aug 2, 2010 | 04:55 PM
1966sportfury's Avatar
A.K.A Bob Dodge
my guess is the float sticks when it reaches a 1/4 tank
Old Aug 3, 2010 | 06:29 PM
DustinHeck's Avatar
how do i fix it put a new one in or pull it out and spray some wd-40 on it
Old Aug 3, 2010 | 09:40 PM
A.K.A Bob Dodge
pull it out 1st and check to see why the float sticks, if you can free it up or not, if not then you may have to buy a new one,
it may not even be the float, but its a place to start,
Old Aug 4, 2010 | 08:50 AM
DustinHeck's Avatar
OK thanks
Old Nov 13, 2013 | 09:51 PM
daisyjohn's Avatar
Disconnect the tan wire involved with the connection between the gauge, and check it (run a finger along to wire) to see if there is any wear and tear along the wire. Replace the wires and make sure that everything is connected and grounded properly to check it if works.
Old Nov 14, 2013 | 09:48 AM
The rheostat in the sending unit is probably bad / rusted. Get a rheostat 150-200 ohms Hook it up to the sending wire & adjust it while watching the gauge
BruceJ
Oct 15, 2011 10:44 AM
Ramahan
Feb 5, 2011 05:43 AM
Evnas
Apr 12, 2009 06:13 PM
ef8340
Dec 17, 2008 12:07 AM
