Mopar Forums (/forums/)
-   94-Current Dodge Trucks (https://moparforums.com/forums/f18/)
-   -   my gas gauge will not work right (https://moparforums.com/forums/f18/my-gas-gauge-will-not-work-right-7086/)
DustinHeck Aug 2, 2010 12:28 PM
I have a 1990 dodge ram d150 the gas gauge dont work below 1/4 tank and some times it gos to empty what the heck pleas help thanks
1966sportfury Aug 2, 2010 04:55 PM
my guess is the float sticks when it reaches a 1/4 tank
DustinHeck Aug 3, 2010 06:29 PM
how do i fix it put a new one in or pull it out and spray some wd-40 on it
1966sportfury Aug 3, 2010 09:40 PM
pull it out 1st and check to see why the float sticks, if you can free it up or not, if not then you may have to buy a new one,
it may not even be the float, but its a place to start,
DustinHeck Aug 4, 2010 08:50 AM
OK thanks
daisyjohn Nov 13, 2013 09:51 PM
Disconnect the tan wire involved with the connection between the gauge, and check it (run a finger along to wire) to see if there is any wear and tear along the wire. Replace the wires and make sure that everything is connected and grounded properly to check it if works.
TVLynn Nov 14, 2013 09:48 AM
The rheostat in the sending unit is probably bad / rusted. Get a rheostat 150-200 ohms Hook it up to the sending wire & adjust it while watching the gauge
