need help with a decision
Yes im have a 04 ram 1500. im trying to get as much horsepower as i can out of it what should i do to start off? i want to do the small and cheeper things first. thank you
What do you have for a motor now? auto or manual? 4wd or 2wd?
Air intake, headers, cat back exhaust and a computer is the easiest and cheapest. after that, injectors, cam, head work, tranny and torque convertor, gears, posi, etc. |
Tim summed it up
what about cold air intake? |
Originally Posted by 67 GTX
(Post 22604)
Tim summed it up
what about cold air intake? Thats what I meant by air intake. Throttle body is a good one too along with a throttle body spacer. We need some more info though to really be able to help you out in getting the most out of your truck. |
it a 5.7 1500ram 4X4 automatic
Cold air intake, headers, cat-back exhaust, free flow cats, and programmer is where I would start.
Then a look around for an underdrive pulley kit, performance coil packs, posi in the rear axle, shift kit for the tranny. If you are still wanting more then you will need to dive into the motor with a cam, head work, injectors, and computer tuning. There is a lot of parts out there and a lot of them are all the same, it's just the name that you are paying for. |
thank for all the info it is goping to help me is there any certian places i should look for parts?
I look on summit racing and then hit up the local speed shops as they can usually beat most of the larger companies prices. Personally I like to support the small, local guys as the more you do business with them, the more likely they are to give you a deal on a larger order now and then.
Another good place to go is E-bay. I've been seeing a set of $450 Gibson headers for my V6 Dakota sell for only $200 on there........ brand new. |
Bully dog chip...
Originally Posted by 78D200
(Post 22617)
i'll just leave the trucks to you;) |
(Post 22671)
Ah, sorry there Tim
i'll just leave the trucks to you;) LOL. don't be sorry. |
6.1 cam
Originally Posted by johnthegoalie
(Post 22813)
6.1 cam
Why not the rest of the motor? |
