new style 318 to old style 360 engine swap?
hey i've got a 99 1500 with a 318 in it i also have an old style 360 is it possible to swap motors and just put my intake on the new motor or is that not possible because the magnum set up is so different from the old style?
it will not work. the block and heads are different between the Magnum motors (newer) and the LA motors (older). you'ld be better off just finding a magnum 360 to swap in.
