Mopar Forums (/forums/)
-   Dodge Durango (https://moparforums.com/forums/f19/)
-   -   runnin rich (https://moparforums.com/forums/f19/runnin-rich-14308/)
crash Feb 22, 2013 04:48 PM
runnin rich
have a 2002 durando with the 4.7. its running really rich,any ideas on how to fix this problem. thanks for your help.
78D200 Feb 23, 2013 03:05 AM
Check engine light on? If so, what codes are being thrown? could be a clogged cat blocking the down stream O2 sensor, could be a stuck open injector(s), bad plugs and/or coil pack, etc.
How do you know its running really rich?
pro-tech Feb 23, 2013 05:07 AM
The most common problem with the 4.7 L engine is they drop valve seats causing the engine to run rich & skip.Is it skipping? Do a compression test. The rich running happens when it drops the intake seat. The head will have to be replaced or rebuilt. But sometimes they cant even do that. The new heads from Chyrsler are not as bad as you would think because they know they have a problem so they feel they should be reasonably priced. What Tim said is also very valid too. Keep us posted..
Gorts 5th Feb 23, 2013 05:32 AM
you got too be kidding me!
they drop their valve seats!
fricken engineers can't make anything today that lasts!
Making it cheaper makes it weaker.
crash Feb 23, 2013 05:58 AM
check engine light is on...dont know the code # but was told it was a vacuum problem.as far as knowing that its running rich,my wife parks in in the garage and when she starts it in the mornings you can really tell.i have had probs with one of the heads pushing off rockers but ive had that fixed.thanks again for the help.
TVLynn Feb 23, 2013 01:57 PM
Almost as bad as the 2.7 THERE is no reason they can't make an engine to last 250K miles
pro-tech Feb 24, 2013 01:02 PM
If it is pushing off the rockers that is what they do if the seat falls off the head. It holds the valve open the rocker is then real loose and it falls off. Sometimes the seat will find its way back into place but doesnt last long. It ends up beating the head to death and the core is ruined thus causing the customer/person to buy a new head and thats why the cost is reasonable because chrysler knows they have a problem. We were doing them under warranty even. I believe the new heads have the seats staked in now.
crash Feb 24, 2013 10:52 PM
ive had the head issue fixed it just runs really rich and i dont know where to start to fix that.
pro-tech Feb 25, 2013 05:59 AM
Have it checked for codes! It would be alot easier to help you if we had all the facts. A vacuum leak would make a rough idle and should be easy to find.
crash Mar 8, 2013 04:29 PM
got a code its... po440
PK1 Mar 8, 2013 06:10 PM
SYMPTOM
P0440 - GENERAL EVAP SYSTEM FAILURE
WHEN MONITORED
Engine Running. Fuel Level greater than 12%. Ambient Temperature between 4 °C and 32 °C (39 °F and 89 °F) .
SET CONDITION
The PCM does not see the NVLD switch close during the medium/large leak test. The PCM then will increase the vacuum supply to the EVAP system by increasing flow through the EVAP Purge valve. If the switch does not close with an increase in vacuum an error is detected. Two Trip Fault. Three good trips to turn off the MIL.
POSSIBLE CAUSES
  • EVAP PURGE SOLENOID VACUUM SUPPLY
  • (Z938) GROUND CIRCUIT OPEN
  • (K107) NVLD SWITCH SIGNAL CIRCUIT OPEN
  • EVAPORATIVE EMISSION LEAK DETECTION
  • NVLD ASSEMBLY
  • PCM
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding
crash Mar 8, 2013 06:54 PM
thanks for the info pk
