4.7 dying
Old May 7, 2010 | 06:49 PM
1966sportfury's Avatar
A.K.A Bob Dodge
4.7 dying
on my way home from work i put my 05 dakota in neutral (automatic) at about 30 mph. rolled to a stop. at the stop light hit the throttle nothing. engine died (didnt hear the engine radio was up) started it back up, started right up i put it in drive and went. so i played around with it a little bit. everytime i would put it in neutral from a cruising speed it will die. sumtimes the rpm's will jump from 400 to 800 but it will eventually die. come to a stop put it in neutral its fine. rev it up a bit in neutral its fine. it wont die unless i put it neutral at a cruising speed. check engine light isnt on nor does it come on before it dies. what would cause this? any ideas?
Old May 7, 2010 | 08:07 PM
johnthegoalie's Avatar
thinkin with me dipstick
have you cleaned the throttle body yet? both it and the throttle position sensor have a habit of getting gummed up affecting idle, etc. also go in the truck turn the key back and forth from the on to the off position until the odometer reads "done" right after that the truck will flash any present codes. the check engine light doesn't have to be on for codes to be present.
Old May 7, 2010 | 08:08 PM
oh, and why are you coasting in neutral to stops?
Old May 7, 2010 | 08:11 PM
A.K.A Bob Dodge
thanks for the reply.. i dont coast to stops all the time i just did it really dont know why just did. one of the things.. ill check it out thanks!
Old May 8, 2010 | 08:17 AM
A.K.A Bob Dodge
i tried this and it never said done. i turned it to just where the odometer lit up. at least for a minute.on,off,on,off. then i turned it to where the whole dash lit up. each time about a minute or longer... im gonna clean the throttle body, ait senser and throttle position senser.. and got a exhaust leak and it getting louder drivers side i hope its not a manifold gasket. hope its the doughnut. or whatever they use now.
85Dodge440
Nov 2, 2013 04:33 PM
grease-monkey
Oct 23, 2011 01:16 PM
buddyleewv
Aug 17, 2010 08:23 PM
