concerned about new vibration
hey everyone
I have a vibration question (again it seems) I am not sure how well balanced these 4.7's are but mine has a knocking type vibration that is there most of the time it is like a hammer tapping that goes faster as I accelerate. It is there predominantly when in gear and the engine is under load. If I take it out of gear or depress the clutch while drivinghttp://images.intellitxt.com/ast/adTypes/icon1.png, the vibration diminishes greatly. I have recently changed tires which helped some of my other issues and I changed the exhausthttp://images.intellitxt.com/ast/adTypes/icon1.png (which I checked and it is not hitting anything. the other strange thing was today in the driveway, the front developed a kind of shimmy - it felt like it was going through the shakes. I did have it into Dodge in the fall to check the driveshafthttp://images.intellitxt.com/ast/adTypes/icon1.png and everything checked out ok. This has me rather concerned as it is my only mode of transportationhttp://images.intellitxt.com/ast/adTypes/icon1.png Any ideas thoughts or suggestions on what this could be would be greatly appreciated. thanks Sean |
almost forgot - 2006 4.7 slt extended cab 2wd -
thanks |
Got a wrist pin knocked out of it in the motor?
ok - I am going to sound stupid - can you explain what that is?
thanks |
Make sure it is running on all 8 cyl
Connects the rod to the piston...
would I notice that whether it was in gear or in neutral? I also read somewhere that it could be loose or broken exhaust stud -?
thanks Sean |
Post up a good video.... Maybe we could get a better idea on whats up???
Make sure the flex plate bolts are tight
The 4.7L engine also has a problem with dropping valve seats and it causes a knock and miss-fire...Bill
two questions- is the flexplate in with the flywheel and clutch?
and can I check the valve seats from above or will i need to remove the head? thanks everyone Sean |
No, flex plate is automatic, flywheel is stick.
thanks - that is what I thought - can I ask another stupid question? I just installed a new muffler and pipes - it is a little louder (Hooker aerochamber)
the more I listen the more the pounding sound is like a loud pulsing/hammer tapping type sound - could that be the way the exhaust is distributing the sound note? I would have thought this more but I can feel the vibration in the stick which makes me wonder thanks very much everyone Sean |
