Mopar Forums (/forums/)
-   Current Jeep Models (https://moparforums.com/forums/f29/)
-   -   2007 Jeep G. Cherokee Quadra-Drive axle leak, driver side (https://moparforums.com/forums/f29/2007-jeep-g-cherokee-quadra-drive-axle-leak-driver-side-22629/)
ZCAR Sep 5, 2019 06:23 PM
I have been building race differentials for years, pulled the front apart to replace bearings, seals, new CV axle on driver side, new Mopar seals & mounting bushing, everything went great, reinstalled with no problem, test drove 2 miles & gear oil pouring out between seal & new axle, pulled down & replaced that seal twice with the same results, can’t see a problem anywhere, very puzzled, please looking help, customer trying to get back home from storm on the east coast
RacerHog Sep 6, 2019 05:39 AM
Cant I have ran into that problem.... But sounds like Wrong Parts to me in this case....
ZCAR Sep 6, 2019 05:43 AM
I used OEM Jeep seal & new Precision CV axle
RacerHog Sep 6, 2019 05:55 AM
This is not an SRT? Correct?
RacerHog Sep 6, 2019 06:08 AM
Sure sounds like an inner seal issue? Seals fit the axle tight?
ZCAR Sep 6, 2019 06:51 AM
It’s not a SRT
ZCAR Sep 6, 2019 07:09 AM
It leaked the same with the old axle as well as with the new axle, changed seal twice
RacerHog Sep 6, 2019 08:42 AM
OK.... But...... Did you test fit the seal to the axle ?????? If not, I would would suggest that you do so.
Post up some photos if you can.... Something is just weird here... 4 seals and they all leaked... Mind boggling to say the least.!!! Will help you find it if we can... :)
I'm sure the customer is not happy at this point.... :( :(
But now's the time to fix it !!!
xaza Sep 6, 2019 06:31 PM
If you overfill the axle it will squeeze it out when it heats up and expands. Had this issue once when filling my axles on XJ and didn't account for the locker taking up space and reducing volume capacity. When installing axle use small amount of clean oil on rubber part of seal and small amount of rtv sealant to seal to axle housing. Also use a caliper and verify that the axle and seal are the right size.
