Clutch replacement/repair cost
Old Nov 26, 2013 | 02:44 PM
Abuong01's Avatar
I've been quoted 550 for parts and 805 for labor to replace the clutch in my 64 v8 barracuda. Apparently the original 9" isn't available but that shouldn't be an issue given they availability of 9.25 and 10"
Any thoughts....my first barracuda and I'm needing some help to know what makes sense for a replacement. I found OEM plus throw out bearing for about 225 online. Why 550 bucks?
Thanks in advance for the help guys
Old Nov 26, 2013 | 04:15 PM
If you go to a 10" clutch you would need a flywheel, clutch disk, pressure plate through out bearing and maybe a new belhousing ??? I would check with Summit Racing OR Ebay $800 for labor ??/ or is that the total ?
Old Nov 26, 2013 | 04:29 PM
http://www.autopartswarehouse.com/sk...E52541403.html
The listing says 10" clutch ??? Have you taken it apart ? Was it changed from a 6 cyl ?
Old Nov 26, 2013 | 04:30 PM
moe7404's Avatar
on some older mopars I.E. 9" a 10"-11" clutch may not clear the bellhousing. if memory serves me. right.
Old Nov 27, 2013 | 10:21 AM
Abuong01's Avatar
They quoted 550 for parts and 800 for labor on the original quote. Now asking me to call them because they cannot get the 9 inch which was supposed to be original equipment in the 273 V8.
Old Nov 27, 2013 | 11:59 AM
800 is terrible !!! You can change a clutch in 4 hours
Old Nov 27, 2013 | 12:42 PM
Abuong01's Avatar
They have 8 hours at 95 per hour. Pull the transmission, etc is what they said had to be done. Feel like I'm getting boned
Old Nov 27, 2013 | 02:32 PM
Here's something 9 1/4 clutch listed for a 6 cyl but may be what you need ???
http://www.autopartswarehouse.com/sk...%26+Drivetrain
and someone who does clutches and has the air tools could probably do it in 2.5 hours + 1/2 to jack it up and support on jack stands.. 4 bolts and the drive shaft comes out, 2-3 bolts and the shifter comes out 4 bolts on the cross member 2 bolt on the trans mount. 4 bolts and the trans comes out !! 2 bolts for starter 5 bolts for the bell housing. 6 for the pressure plat and another 6 for the flywheel... an an air ratchet /impact makes quick work of it... Send the flywheel to machine shop and have it re surfaced re assemble with locktite on bolts
Old Nov 27, 2013 | 06:22 PM
mikerp76's Avatar
if it takes them 8 hours they must work really slow.
Old Nov 27, 2013 | 08:12 PM
The biggest scam is the labor rate manual
Old Nov 27, 2013 | 08:52 PM
Abuong01's Avatar
Thank you everyone for the help and education. I'm going to challenge the labor hours..is there a "book" that suggests how long something should take like there is for modern cars.
Old Nov 28, 2013 | 01:26 AM
No sense challenging them... LOOK for a different mechanic !!!!
scotty
Dec 20, 2011 12:58 PM
sebring28
Nov 5, 2011 03:50 AM
dnlwstwd
Oct 12, 2011 08:08 AM
RROriginals
Aug 23, 2010 02:44 AM
JeepChryslerDodge
Feb 12, 2010 03:58 PM
