damn wiring need help
ok so i was driving my cuda around and it just lost all electrical. I got it home found that power wire coming from the battery to the terminal block blew the fusable link. Replaced that now I have power everywhere but it still wont even crank via keying it. I can jump the solinoid but still no spark. Its got 10 volts to the coil. Any help would be great.
You didn't specify what year your car is but you can get schematics for free at:
http://www.mymopar.com/wiringdiagrams.htm Where to start with your limited information... you may have a problem in the dash area. Check your ammeter connections and/or bulkhead connections for opens. Also check your neutral safety switch for correct operation if your starter is not working. I can get more specific if you define the problem better. |
| All times are GMT -7. The time now is 06:53 AM. |
