Mopar Forums (/forums/)
-   Street n Strip (https://moparforums.com/forums/f32/)
-   -   408 build questions (https://moparforums.com/forums/f32/408-build-questions-19484/)
85dodgeram350 Jun 13, 2016 07:13 PM
408 build questions
Hey guys I'm building a stroker 408 for my truck and was at a local swap meet and saw some j heads with 2.02 intake valves and it has valve springs for 650 lift cam not sure on what brand valves or if it has 3 angle valve job and has Harland sharp roller rockers 1.5 ratio guy raced it then in a dart that ran 10's he only had 300 passes bolt on ready he's asking 850 was wondering if it is worth it? With my build I am wanting to run 10.5:1 compression bottom end had eagle rods windage tray and arp bolts I'm gonna run Edel rpm intake with Holley 750 I was shooting for 450-500 hp and also a any input on a good cam to go with this will be mostly street driven and little track and also has a 4 speed behind in thanks in advance sorry for how long this is haha
RacerHog Jun 13, 2016 07:27 PM
Do overs???? lol
TVLynn Jun 14, 2016 10:18 AM
Better off with some aluminum heads. J heads with 202's are beneficial only if you are planning 7K RPM motor
85dodgeram350 Jun 14, 2016 06:28 PM
Ok so if I go with a set of aluminum do I want 2.02 valves or smaller cause my motor will probably not see past 6500 rpm
85dodgeram350 Jun 14, 2016 06:29 PM
Originally Posted by RacerHog (Post 134020)
Do overs???? lol
Didn't know if there were different people in this section lol to get more replies
RacerHog Jun 14, 2016 06:36 PM
lol....It's all good.... :)
