Mopar Forums (/forums/)
-   Street n Strip (https://moparforums.com/forums/f32/)
-   -   slow 69 cuda help plz (https://moparforums.com/forums/f32/slow-69-cuda-help-plz-263/)
Rulito Jun 20, 2007 11:23 PM
Hi, first of all, excuse me my bad english.
Originally i had a 69 barracuda with 2 barrel factory intake and factory carb, points ignition, 4 speed trans and 3.2 gear on a danna 44, i went to the drag and the 1/4 mile was on 16.3 seconds. Then i change the intake to a Weiand X cellerator and a Carter 600 cfm carb, Crane Hi-6 Ignition, 3.73 gear, i welded the diferential in order to obtain traction from both wheels, i went to the drag again and i get 17.5 seconds!!!...
i have a factory cam, but today i received a new 274 comp cam and im planning to make a dual exahust system, so.. the question is.. why my car is slower than before?, what can i do in order to be faster?
Thanks for your atenttion
General pavelka Oct 3, 2007 08:05 PM
you need heads, 906 castings or something, 2.14 intake try an m1 intake you can spin it 7500rpm dominator carb headers 2 inch runners is this a big block? stub connectors will help.
1 Bad Mirada Oct 10, 2007 11:24 AM
i seriously doubt that its a big block...i dont think that they made any 2bbl big block cudas...im guessing that he has a 318 or 273, if its a factory 2bbl car and engine. then again, i could be wrong..
first, is the carb tuned properly? does the car feel like its running ok?
is that weiand intake single or dual plane?
when you ran, what was your mph? 17.5 at what speed? and when stock, 16.3 at what speed?
Gorts 5th May 29, 2012 02:18 PM
you need heads and a cam 360 heads are a good start
sounds like your drowning the engine with to much intake
flow then it hits the small heads and valves and it slows the car down
if you install stock 4 bl 360 heads on a 318 you will notice a big gain in power and thats jst stock i use a set with the smaller valves but i maxed out the port job makes great power woo hoo!!!
TVLynn May 29, 2012 04:45 PM
Have you checked to make sure you are getting full throttle since the manifold change
moe7404 Nov 14, 2012 05:40 PM
if you want to go fast build your chrysler just like chrysler made it!!!! i have seen this a LOT. a friend and his buddys build max-wedge cars. one guy thought he would out trick chrysler, buy useing a Holley carb. but he went slower than the factory Carter carb. you may not beleave me but. "sometimes the factory does it right"
Gorts 5th Nov 14, 2012 05:56 PM
yea those Chrysler engineers built some bad azz combos they built there stuff for racing and they did it with carter's today the edelbrock is the closest to it,
i love mine and will never go back to hollie!
chevy small block was invented buy the same guy that invented the ponitac v-8 motor and his design was" cheap and many "
and ford what a laugh just look at how many engine types they have there shite never worked!
Chryco Psycho Dec 14, 2012 06:31 AM
I actually partially disagree on the Ford comment , while I am not a fan , Ford was the only competition Mopar had in Nascar , look at the record books Gm complained & rules where changed to limit the Ford & Mopars so Gm could be competative , same in drag racing SS/A is not limited to Mopar but nothing else competes , in Prostock Mopars were handy capped but 400lbs or more if they used the Hemi . I do agree Ford had 7 different blocks , nothing interchanges , 4 engine at the 7 lt Nacar limit all with different designs & no interchangability !
I wonder if Pavleka is coming back ? probably a 318 , while the 318 is very similar to the 340 it was missing all the good parts , cam ,heads, intake,carb, exhaust & most of all compression .just throwing 4 bbl on them rarely helps !
Gorts 5th Dec 14, 2012 06:38 AM
never say never.
440roadrunner Dec 14, 2012 08:36 AM
I've never read so much BS in my life.
A GOOD mechanic can make EITHER a Holley or Edelbrock run, assuming they are not a mismatch for engine size, etc
The Weiand manifold you have is USELESS for a low rpm engine, which is what you have. What you want is something like the Edelbrock performer
Putting 360 heads on a 318 (IF that is what you have) is not the answer unless you also either mill the deck/ heads to increase compression, or change the pistons, or both BECAUSE the 360 heads are going to drop your compression ratio
If the engine is in good condition, if this is a fairly low budget build, leave the heads alone. Get a manifold which is designed for the engine. Frankly, something similar to the FACTORY 360 intake, even when installed on the small-port 318 heads, is way way better than ANY 360 degree design manifold
Dual exhaust should have been the FIRST thing you did, not the last. Trying to force more flow through a single exhaust may very WELL slow the car down!!!!
Don't go overboard on the cam. A good cam is a modern day equivalent of the old 340 68 "stick shift" cam. Several manufacturers make them.
If the above does not do it for you, then you are into heavy work, IE mentioned pistons, milling, etc, or look for a 340/ 360. Also bear in mind that milled heads/ deck also usually requires that the intake or intake side of the heads be milled to match, and you'll have to get adjustable rockers/ pushrods, or at the very least, carefully measure for correct (custom length) pushrods.
Archer Dec 14, 2012 09:43 AM
Gents -
I know this stuff is timeless, but you realize this is a 5 year old thread, right???
Mr.4spd Dec 14, 2012 06:28 PM
I noticed too, totally worth 440's carb comment though.
