Anyone in AZ
The wife and I are looking to relocating to Yuma AZ. Can anyone tell me about the inspection laws on cars such as emissions testing and such?
We both have 78 model cars one Chrysler Cordoba without the lean burn system and my 78 Magnum GT which will be converted over. |
I read a little bit and Yuma seems exempt. You can read more below. Hope that helps.
From the AZ DMV: Vehicles Registered Outside of the Vehicle Emissions Control Areas (metro Phoenix and Tucson) in Partially Exempt Zip Codes The Motor Vehicle Division exempts most vehicles registered outside the vehicle emissions control area based on the residence zip code. However, the zip codes listed below* are considered partial, meaning parts of the area require emissions and some parts are exempt. *Partial Zip Codes in the Vehicle Emissions Control Areas (effective July 2009):
Those vehicles may be granted an Out of Area (Status Code 52) Exemption if they are registered in that partial zip code and out of the emission control area boundary. However, if the vehicle is used to commute into the emissions test boundary (area A or area B) for employment or school then by State Law, the vehicle will be required to go through testing. Note: This information is not targeted to just Maricopa and Pima Counties, but also parts of Pinal and Yavapai. To verify this information, you may use our VEI Address Locator. http://www.azdeq.gov/environ/air/vei/exempt.html Unless specifically exempted, all 1967 and newer vehicles (including diesels) that are registered in the metro Phoenix (Area A) or Tucson (Area B) emission test areas must receive an emissions inspection no more than 90 days prior to registration. Exempted Vehicles
http://www.azdot.gov/mvd/vehicle/vehicleservices.asp |
Thanks Morrigan, I read that this morning but still seems a bit confusing...
I'd just type in Yuma's zip code in the address locator.
Originally Posted by Morrigan_Aria
(Post 40038)
Yuma is almost California. So if you let the map load, you'll see Yuma isn't anywhere near Tucson or Phoenix. So no, you don't have to DEQ your cars.
(Post 40042)
Like my Belve would? There's more than one reason to live in the sticks!~
have you been there in the summer yet?
Originally Posted by johnthegoalie
(Post 40078)
I use to drive a truck cross country. So yeah I know it gets hot. |
hot is an understatement...
(Post 40086)
yup, really nice winter followed by 8 months of hell
