Who peep my iPod Touch?
Recently the news spreads around that the nude photos are put wantonly on line. Here I want to say that if the stars can learn more about code protection and have the sense to save information, I think the things won’t be like this and can not stop. iPod Touch has the function to protect your privacy via the password. If your iPod Touch has contained your secret, you should remember to set the password. People are interested in the privacy of others. If not so good, if it is yours. 1. Choose “General” “password lock” in “settings” 2. Type the number password into the requested blank in correct order. Then do it once again to confirm it. 3. Set the time when you need password. The shorter the time is, the safer your iPod Touch is. 4. After setting the password successfully, the tab “password lock” shows “open”. 5. The running state is as follows after setting the password. Type the password that you set then you can run it. |
| All times are GMT -7. The time now is 02:26 AM. |
