Mopar Forums (/forums/)
-   -   1968 Charger, replace 318 with 440 (https://moparforums.com/forums/f4/1968-charger-replace-318-440-a-20602/)
Moses440 Aug 13, 2017 07:54 AM
I have a 1968 Dodge Charger with a 318. We would like to change the 318 with a 440. What will I have to do or issues that I will face.
Thanks
fivepoint Aug 13, 2017 05:10 PM
When I did my swap, I used a kit from Schumacher Creative Services. Then you more than likely need a larger radiator. I had a 22 inch, went to 26 inch aluminum. My B body had drum brakes on all four corners. Decided to convert to disc on the front . Then I found a differential with disc already on it a went disc all around. It is a pretty simple swap.
