Mopar Forums (/forums/)
-   -   1973 Dodge D-200 (https://moparforums.com/forums/f4/1973-dodge-d-200-a-24490/)
MicheleCameron Mar 19, 2022 08:54 PM
1973 Dodge D-200
Hi, newbie here... My 1973 D-200 PU is no longer showing up in online search results and I need to get some ATF. I put my manual somewhere for safe-keeping. Can I use Oreilly Premium ATF ? bottle says "for use where Dexron-3 or Mercon fluid is specified. thanks.
RacerHog Mar 20, 2022 07:48 AM
F-Type was used in the older trans.....
If the trans has been overhauled with all the updated clutches then the Dexron or ATF+4 can be used...
Iowan Mar 20, 2022 05:39 PM
Just plain old type F is all you need….
Skwerly Mar 23, 2022 02:43 PM
Yep, just this stuff here. Long as it says Type F, you are good to go!
