1974 Dart | Magnum 360 Swap Advice
Old Mar 24, 2020 | 03:54 PM
apexautoaz's Avatar
I lack experience with vintage Mopars and could use some help from you guys on finalizing a list of needed parts for this project.
Thus far, I removed the Slant 6 and cataloged the parts. The S6 has been retired.
Transmission: Old vs Newer vs Adapted
  • Old: The 904 or 727 small block pattern will bolt up to the newer 360. Column or Floor shift; rod or cable, lots of questions. Why would I go with an old 3 speed? I can't think of a single reason.
  • Newer: 46RE with an aftermarket controller from http://www.e-transcontrol.com/tcm932/; seems like a better option...controller is 750.00. Need to decide on shifter. Kickdown is cable operated; easier than the rod style.
Other Questions:
  1. Steering Link; does the S6 center link clear the v8 oil pan?
  2. Radiator / radiator mount: I know the V8 radiator is larger; are there other mounting considerations such as necessary hardware or brackets?
  3. K member: original shows impact damage, wouldn't mind replacing. Years to look for?
  4. Engine mounts? Adapt current K member with aftermarket mounts; or, better to swap K members; or buy aftermarket?
  5. Oil filter clearance:\ will the 90 degree adapter be needed?
  6. Firewall clearance: Is this a drop in fit; or will firewall mods be necessary?
  7. Exhaust manifolds / headers: What will clear
  8. Torsion bar upgrade; is this recommended?
2001 Magnum 360 w/ EZ-EFI
This is a sales flyer photo of the engine chosen by the customer.
Old Mar 25, 2020 | 09:38 AM
Nice, seems like a fun swap! Are the brakes different on 6 cyl vs 8 cyl models? I’d want that puppy to stop OK lol.
Old Mar 25, 2020 | 10:20 AM
apexautoaz's Avatar
Currently, there are factory disc brakes up front; upgrades are up for discussion.
Old Mar 25, 2020 | 11:50 AM
Look for a v8 K member as some of the magnum blocks had the car mount boss's making it a bolt in.
adr
Feb 28, 2018 01:49 AM
Tdubs
Mar 4, 2017 05:01 AM
Nathan talley
Mar 14, 2014 10:22 AM
slim689
Apr 22, 2011 05:53 AM
alanp123
Jun 3, 2008 01:51 AM
