Mopar Forums (/forums/)
-   -   1994 Dakota intermittent misfire (https://moparforums.com/forums/f4/1994-dakota-intermittent-misfire-1056/)
David Blair May 15, 2008 04:59 PM
I have a1994 Dakota 3.9 v6 that misfires occasionally.I have exchanged all ignition parts with those from a truck with no miss but cannot cure the problem. New wires ,new plugs.new rotor and cap didn't fix the problem.The fuel pressure is about 3 lbs low but doesn't change when the miss occurs.It might miss ten times a day or not do it for a week .It never lasts long enough to identify the cylinder or cylinders involved.Usually occurs just before or just after the 1-2 shift(automatic transmission)Pulling hard like up hill doesn't make it miss. What do I try next?
78D200 May 16, 2008 01:03 AM
scan tool will help to id which one(s) of the cylinders is misfiring. I'd start there.
David Blair May 16, 2008 07:49 AM
scan tool
This is too old for OBD11.Scan tool shows no codes except for the ones created as I swapped sensors,which I erased.i have read that a fuel pump can cause this problem even with pressure that is within specs.What do you think? A fuel pump is expensive but worth it if it is the cure!
78D200 May 16, 2008 09:21 AM
I have heard that also about the fuel pump. I can't tell you for sure though is that is the problem. Hopefully there are a couple of dodge techs here that will chime in.
kttim61 Mar 13, 2010 12:55 PM
Dakota
Have you figured out the problem? My truck does the same thing and we are unsure. We have done everything even replaced the intake manifold gasket (plenum gasket) and it still randomly misses. It seems to be something with fuel but the pressure read ok.
78D200 Mar 14, 2010 04:48 AM
Clogged injector? What tranny do you have? There is a sensor pickup on the autos (I believe and have seen those cause issues in the Dodge Ram trucks
