413 Question
I am looking at a 413 is there anything Tolook for and where can I find performance stuff for it? Thanks john
I just found a 413
I Have a question for you. I have just found out that the motor in my 71 rv is a 413 (found the number stamped on a plate behind the water pump) it is stamped HT 413 do you have any idea what the HT means and also where on the block is the serial number or part number?.
pre 1974
i would look for a pre 1974, bigger valves no emmission laws. if your lookin for a bone stock motor look for an hp on the pad probably an e code. thats what i would look for.
regards, general |
HT? Might mean "truck?" Are you sure it isn't a poorly stamped "P"
HT is truck engine... serial number on the side of the block large numbers... serial number bottom edge of the block on the side where the oil pan mounts where the oil pan mounts
ANYONE have any of these motors or parts laying around?
| All times are GMT -7. The time now is 04:10 AM. |
