Mopar Forums (/forums/)
-   -   65 Fury 727 Trans shift Cable Adjustment (https://moparforums.com/forums/f4/65-fury-727-trans-shift-cable-adjustment-20589/)
Randy9207 Aug 10, 2017 07:34 AM
Hello
New to forum hope someone can help.
Recently purcased a 65 Fury with automatic
Column shift engine will not crank in park
Only in neutral do I adjust at trans or is their
Another way on the column? Thanks
TVLynn Aug 10, 2017 02:52 PM
I can't tell you how, but search and their is lots of info about adjusting the cable
Randy9207 Aug 17, 2017 09:15 AM
Thanks tvLynn
Appears I may be able to adjust same as floor shifter.anyone ever had to adjust a
Automatic column shift cable??
