Mopar Forums (/forums/)
-   -   Alternator Question - Over Charging?? (https://moparforums.com/forums/f4/alternator-question-over-charging-3327/)
mikeynags Jun 16, 2009 05:55 PM
The following done to a 1970 Plymouth roadrunner.
Installed new Autometer Voltmeter and it shows 14.5 volts at idle, 12.5 @ idle with the lights on. When you bring the RPMs up it goes to almost 16 volts on the gauge. Replaced both the alternator and the voltage regulator at the same time and I am still seeing the same result. Is this just typical for an old mopar or do I have a potential electrical problem? It seems a bit high to me. The built in gauge shows a bit of a charge (10-20AMPS) after you first start the car but once the car warms up the gauge is in the center between "D" and "C". Also, I measure about 12.5 volts @ idle right on the battery and about 14 volts if you bring the RPMs up. Is it a bad gauge or do I have something else going on?
Polaradude Jun 16, 2009 05:59 PM
see Scott and your other thread.
scotts74birds Jun 16, 2009 06:31 PM
See you other post
