ebody jig
Old Nov 28, 2012 | 11:34 AM
plymouthrocks's Avatar
ebody jig
Was wondering if anyone knows how to build a jig for an ebody. I would like to replace the frame rails, inner fender, and the shock tower as sold by dynacorn. Thanks
Old Nov 28, 2012 | 11:43 AM
I'm not bodyman at all, but some of the factory manuals have the chassis measurements buried somewhere
What year / model is your car?
Here (for example) is a complete 70 manual, from MyMopar
Direct link. You have to "unzip" it
http://www.mymopar.com/downloads/ser...ice_Manual.zip
Now, the page numbers in the pdf are consecutive, IE do not folllow the original Mopar "dash" system, so you have to hunt a little
Page 1197 in my browser shows a 70 Cuda
Old Nov 28, 2012 | 02:59 PM
Need to weld X bars across the door openings & an X bar/s from side to side
Old Nov 28, 2012 | 03:30 PM
Years ago I built a wooden jig with the rockers resting on top, punched lower lip screwed into wood with both sides tied together, almost like a big upsidedown picnic table. Sounds a little hoaky but worked great. Today I'd probably weld up something similar in steel.
I always suggest taking 8 height measurement with engine and trans in, on the tires. Mearure where the subframes meet the floor near the torque boxes and at the end of the front and rear frames rails. A flat concrete floor helps but not critical as long as you duplicate it later. If you cut the front end, suspension height attachment points can be duplicated with factory manual, string and a level. Remember 40 year old cars sag when lifted.
Old Nov 28, 2012 | 04:08 PM
Welcome aboard. You can also buy safe-t caps from Autorust and cap the framerails instead of replacing them.
Old Nov 29, 2012 | 03:36 PM
rickyr's Avatar
Old Nov 29, 2012 | 04:17 PM
Can't help on the jig... But welcome to the forum anyway... Be sure to check out the Mopar of the Month contest.....
rottenleonard
Sep 9, 2012 08:53 PM
72ebody
Jul 14, 2010 01:06 PM
rubadub
Nov 11, 2007 02:02 AM
