Help with choosing WHEEL SIZE for 70 Challenger!!!
Old Dec 26, 2008 | 07:25 PM
sirus444's Avatar
Question Help with choosing WHEEL SIZE for 70 Challenger!!!
I have 1970 Dodge Challenger, Rear end (Moser 60/Dana 60), it was built to original specification. Front has Magnumforce E-Body tubular K-member, built to original specification too.
My question is would I be able to fit 235/45-18 (18x8 OFFSET "0") Front and 285/45-18 (18x10 OFFSET "-4") Rear.
I'm open for any suggestion but I want to keep it 18x8 and 18x10.
Thanks
Old Dec 27, 2008 | 09:36 AM
72RDRNR's Avatar
you will need to look at the backspacing of rims also. i think my 72 roadrunner (guessing most mopars were the same) had 4.5" bs. i was able to go up to a 5". the rr have a larger flare on wheel wells but i was able to go 245 up front and 275 out back. think i might have been able to stuff 295 if i put a bit more bs on. you just need to get a set of wheels on and measure how much room you have inside and out.
Old Jan 8, 2009 | 10:38 AM
sirus444's Avatar
Sorry guys, this is probably wrong place to post this question.
Thanks 72RDRNR, I'm going with 5.03" backspacing on rear. After measuring about hundred time. I'm going with FRONT18x8 (+2mm offset), REAR 18x9.5 (-4mm offset).
Haven't gotten to the tires yet. Baught BOSS 338 Wheels.
Old Jan 10, 2009 | 07:00 PM
Apollo's Avatar
Would the back spacing and offset be the same for my 72 Charger? Ive looked all over to find it with no success. I would be going with 15" wheels though
Old Jan 10, 2009 | 08:25 PM
sirus444's Avatar
What's your Rear Axel?
Mine is Moser 60/Dana 60.
I heard that Chargers can go 11" width on the back and backspacing is between 4"-5".
Old Jan 10, 2009 | 09:06 PM
Apollo's Avatar
Not sure how to tell. Its a 72 Charger SE with a 318, auto tranny and vinyl top
Old Jan 10, 2009 | 09:14 PM
if your an auto 318, your probably an 8 3/4 axle
just look at your rear end
if the back piece is welded on, then your have a 8 3/4
Old Jan 11, 2009 | 11:11 AM
challenger's Avatar
Those rims are going to look sweet on the challenger, make sure you let us see them mounted on it
Old Jan 11, 2009 | 01:36 PM
Apollo's Avatar
Thank you 76GTX, and I apologize for the minor thread jack, but since i do have the 8 3/4 axle what is the backspacing and offset for my Charger? I'll be going with 15"s but i would like them as wide as possible front and rear
Old Jan 31, 2009 | 09:25 AM
sirus444's Avatar
I'll definetly put picture of those wheels on my 70 Challenger. I might take me a while because tires cost a lot. About $900.00 for 18x8 front and 18x9.5 rear.
Old Jan 31, 2009 | 09:42 AM
sirus444's Avatar
I would estimate that you can have 5" backspacing. Just make sure that you have right combination of wheels and tires. If not your tires might be touching leaf spring. I would suggest putting one rear wheel without tire and see how much space between wheel and leaf spring you have. Than deciding what kind of tires you need.
Don't go too wide in front because it will be hard to turn the steering wheel, unless you have pump driven steering rack.
Old Feb 1, 2009 | 12:55 PM
challenger's Avatar
well hurry up and get them tires , i want to see them on your challenger hehehe just kidding but really dont forget to let us see it ok as like i said those rims look awsome
Old Apr 30, 2009 | 09:19 PM
sirus444's Avatar
Cool HERE THEY ARE!!!
Partially Rebuild 1970 Dodge Challenger.
Magnumforce front K-Member, 12" all around Willwood Brakes with 18x9 Front and 18x9.5 Rear BOSS Wheels.
https://moparforums.com/forums/pictu...&pictureid=427
https://moparforums.com/forums/pictu...&pictureid=429
BE SURE TO CHECK OUT MY ALBUM PAGE IN MY PROFILE
Old May 1, 2009 | 06:43 AM
72RDRNR's Avatar
Looks good! Did you get the 285's to fit in the rear?? One of my next purchases will be discs all around also (I hope).
Old May 1, 2009 | 08:57 AM
sirus444's Avatar
I got 285, but I could've went with 295. They just didn't have those tire in that size.
Old May 1, 2009 | 03:17 PM
looks nice
oompataylor
Oct 29, 2012 08:46 AM
69POLARA383
Sep 25, 2010 03:59 AM
fury_19
Dec 29, 2009 07:26 AM
SKIN
Jun 24, 2009 07:22 PM
Valcam
May 3, 2009 06:50 AM
