Mopar Forums (/forums/)
-   -   Help with choosing WHEEL SIZE for 70 Challenger!!! (https://moparforums.com/forums/f4/help-choosing-wheel-size-70-challenger-2029/)
sirus444 Dec 26, 2008 07:25 PM
I have 1970 Dodge Challenger, Rear end (Moser 60/Dana 60), it was built to original specification. Front has Magnumforce E-Body tubular K-member, built to original specification too.
My question is would I be able to fit 235/45-18 (18x8 OFFSET "0") Front and 285/45-18 (18x10 OFFSET "-4") Rear.
I'm open for any suggestion but I want to keep it 18x8 and 18x10.
Thanks :confused:
72RDRNR Dec 27, 2008 09:36 AM
you will need to look at the backspacing of rims also. i think my 72 roadrunner (guessing most mopars were the same) had 4.5" bs. i was able to go up to a 5". the rr have a larger flare on wheel wells but i was able to go 245 up front and 275 out back. think i might have been able to stuff 295 if i put a bit more bs on. you just need to get a set of wheels on and measure how much room you have inside and out.
sirus444 Jan 8, 2009 10:38 AM
Sorry guys, this is probably wrong place to post this question.
Thanks 72RDRNR, I'm going with 5.03" backspacing on rear. After measuring about hundred time. I'm going with FRONT18x8 (+2mm offset), REAR 18x9.5 (-4mm offset).
Haven't gotten to the tires yet. Baught BOSS 338 Wheels.
http://www.bigwheels.net/wheels/338%20Chrome_l.jpg
Apollo Jan 10, 2009 07:00 PM
Would the back spacing and offset be the same for my 72 Charger? Ive looked all over to find it with no success. I would be going with 15" wheels though
sirus444 Jan 10, 2009 08:25 PM
What's your Rear Axel?
Mine is Moser 60/Dana 60.
I heard that Chargers can go 11" width on the back and backspacing is between 4"-5".
Apollo Jan 10, 2009 09:06 PM
Not sure how to tell. Its a 72 Charger SE with a 318, auto tranny and vinyl top
67 GTX Jan 10, 2009 09:14 PM
if your an auto 318, your probably an 8 3/4 axle
just look at your rear end
if the back piece is welded on, then your have a 8 3/4
challenger Jan 11, 2009 11:11 AM
Those rims are going to look sweet on the challenger, make sure you let us see them mounted on it :D
Apollo Jan 11, 2009 01:36 PM
Thank you 76GTX, and I apologize for the minor thread jack, but since i do have the 8 3/4 axle what is the backspacing and offset for my Charger? I'll be going with 15"s but i would like them as wide as possible front and rear
sirus444 Jan 31, 2009 09:25 AM
I'll definetly put picture of those wheels on my 70 Challenger. I might take me a while because tires cost a lot. About $900.00 for 18x8 front and 18x9.5 rear.
sirus444 Jan 31, 2009 09:42 AM
I would estimate that you can have 5" backspacing. Just make sure that you have right combination of wheels and tires. If not your tires might be touching leaf spring. I would suggest putting one rear wheel without tire and see how much space between wheel and leaf spring you have. Than deciding what kind of tires you need.
Don't go too wide in front because it will be hard to turn the steering wheel, unless you have pump driven steering rack.
challenger Feb 1, 2009 12:55 PM
well hurry up and get them tires , i want to see them on your challenger hehehe just kidding but really dont forget to let us see it ok as like i said those rims look awsome :D
sirus444 Apr 30, 2009 09:19 PM
HERE THEY ARE!!!
Partially Rebuild 1970 Dodge Challenger.
Magnumforce front K-Member, 12" all around Willwood Brakes with 18x9 Front and 18x9.5 Rear BOSS Wheels.
https://moparforums.com/forums/pictu...&pictureid=427
https://moparforums.com/forums/pictu...&pictureid=429
BE SURE TO CHECK OUT MY ALBUM PAGE IN MY PROFILE :cool:
72RDRNR May 1, 2009 06:43 AM
Looks good! Did you get the 285's to fit in the rear?? One of my next purchases will be discs all around also (I hope).
sirus444 May 1, 2009 08:57 AM
I got 285, but I could've went with 295. They just didn't have those tire in that size.
67 GTX May 1, 2009 03:17 PM
looks nice
