Mopar Forums (/forums/)
-   -   Hey,all.I have a 727 shift problem (https://moparforums.com/forums/f4/hey-all-i-have-727-shift-problem-1224/)
cobaltdkd Jul 6, 2008 08:42 AM
I had my 727 worked on due to a busted reverse band.I got it back and the gentleman who rebuilt it said he lightened it up a bit. It used to bang shift pretty hard. Now first to second is good,but second to third is soft.Any clues? Thanks in advance.cobaltdkd@aaahawk.com
Doc Jul 6, 2008 10:59 PM
Do you know how it check line pressure ? ... BTW - what does the rebuilder say ?
cobaltdkd Jul 13, 2008 09:49 AM
He moved out of town,but told me to adjust the rod from the carb to the trans.I didn't think about line pressure because all other gears work fine.What next?
Doc Jul 13, 2008 03:28 PM
First things first ... check line pressure. It is not rocket-science.
cobaltdkd Jul 14, 2008 05:41 PM
Mopar 727 line pressure
What should the line pressure be?
Doc Jul 15, 2008 01:49 AM
Under wide open throttle ...it should be about 90 psi.
cobaltdkd Jul 17, 2008 04:36 PM
Line pressure
I will check it over the weekend,so I put the gauge in line with either trans line and kick throttle open,it should be 90 psi.? If I find it is not 90 psi,how do I adjust,or can I? Thanks for the help so far.
Doc Jul 17, 2008 11:21 PM
Are you aware where the test "ports" are to pressure-check the trans?
cobaltdkd Jul 19, 2008 06:48 AM
Pressure test ports
No,I am not.Where are they?
Doc Jul 19, 2008 08:18 AM
The line pressure port is on the passenger side of the trans ... about 6 inches above the pan .. in the center.
