Ignition coil wiring
I've got a 1978 Dodge D150 and am fixing a rats nest of wiring issues. There are 6 wires that terminate where the coil should be. One is a heavy gauge red wire. One is a heavy gauge yellow wire. One is a black wire with yellow stripe. One is a thin gauge black wire that goes to wiring harness, 2nd row of connectors from left, top left socket. One is a black wire grounded to voltage regulator. One is a thin gauge red wire from carb choke (probably should have gone to power on firewall but...). Can any one give me some advice as to where these wires go on coil. Thanks.
