Mopar Forums (/forums/)
-   -   Just bought 67 barricuda needs more power. (https://moparforums.com/forums/f4/just-bought-67-barricuda-needs-more-power-15887/)
kgraham Sep 26, 2013 06:44 PM
JUST BOUGHT CAR HAS 273 WITH A 3 SPEED AND I THINK A 7.25 REAR END. The rear end makes a noise when I let off the gas and also have some vibration. When o get around 55 for just a few seconds. IT FEELS WEAK THINKIN G OF 340 OR 360
TVLynn Sep 26, 2013 06:50 PM
You need to change the complete drive train...
IF you want big HP get a 408 stroker small block DON'T try to put a BB in it
RacerHog Sep 26, 2013 06:59 PM
X2.....
kgraham Sep 26, 2013 07:02 PM
Thanks
Coronet 500 Sep 26, 2013 07:30 PM
Welcome. Without knowing the condition of the car I would build a rear to take the future power you plan to make so you can keep driving while building engine and trans.
I use to get all excited in a situation like this and start tearing it apart to be left with a torn apart car I can't drive and lots of thoughts of what it will be. If you go SB stroker when it's ready it will drop right in quickly and have you driving again.
kgraham Sep 26, 2013 07:47 PM
YEAH I THINK I WILL PUT ANOTHER REAR END IN IT. WHAT REAR END SHOULD I PUT IN IT? WILL
A.8.75 work?
moe7404 Sep 26, 2013 08:08 PM
i found a good rear end site.
http://www.forabodiesonly.com/mopar/...d.php?t=120497
RacerHog Sep 26, 2013 08:30 PM
http://www.moserengineering.com/comp...pack-dana.html
https://www.coperacingtrans.com/inde...863bc0dc42502f
http://www.mrlperformance.com/
All the fine ingredient's you need.... :)
You need Help With Installation.... Bring it...I'm only $50.00 Bucks an Hour..
Dont Cause call Us.... :)
Silverick Sep 26, 2013 09:18 PM
The vibration could be as simple as a universal joint...
slade Sep 26, 2013 09:27 PM
a 8-3/4 will work but it must be an A body rear. i think you going with a simple 340 with alittle head and cam work you will be more than happy were are u located?
kgraham Sep 27, 2013 02:26 AM
Located in Cleveland Tn. Next to Chattanooga.
MReeves Sep 27, 2013 04:37 AM
Welcome to the forum.... Doing this one step at a time makes a lot of sense... You get to drive it more and that is what our Mopars are about.. Also be sure to check out the Mopar of the Month contest....
78D200 Sep 27, 2013 04:45 AM
I'd fix the vibration first. Think about what you want to do with the car and base your build on that. Write down everything you want for the build and then start gathering parts. Once you have everything, then start the build. Like others said, this will allow you to still enjoy the car now and the build tie will be shorter.
rickyr Sep 27, 2013 05:50 AM
kgraham Sep 27, 2013 07:33 AM
GOOD ADVICE. I LOVE DRIVING THAT CAR. Bought it to resell but got attached already. Love it.
RacerHog Sep 27, 2013 08:07 AM
WoooHooo... Another Tenn-See-in.... Love the car Dude ...Welcome to the site...
I'm a misplaced TN. boy out here in SO-CAL..... Originally from Memphis :dance:
And Man Do I miss Home !!!!!!
TVLynn Sep 27, 2013 08:25 AM
70-74? Dart, Duster, Valiant, Demon 8 3/4... Easy to change gears on. You could also use a 8 1/4 more for street duty and an occasional drag strip visit - NO slicks
