Mopar Forums (/forums/)
-   -   Mechanical fuel pump predicament (https://moparforums.com/forums/f4/mechanical-fuel-pump-predicament-19426/)
79pw May 19, 2016 06:55 PM
Hello all and thank you ahead of time if you are responding. I recently bought a 79 Power wagon that started off a 318 truck . At some point a 360 from an early 80s van was swapped in and ran for quite a few years before it was parked and sat for just over a year . I had it towed on a flat bed to my garage . Now here's my problem. I wasn't able to get gas up to the carb so I bought a new fuel pump , still no gas , I can draw gas thru the line by siphoning with ease, but very little comes out of the fuel line when the engine is cranking. I'm stumped . Also after removing the old pump I don't belive it was even bad to begin with.
RacerHog May 20, 2016 06:26 AM
Sounds like the eccentric might be bad, loose or cracked... Check it out.... Keep us posted....
TVLynn May 22, 2016 10:17 PM
Check for cracked rubber hoses at the tank !!
79pw May 23, 2016 01:57 AM
Thanks for the replies . I was able to get the truck running . It just took alot more carb priming and cranking then what I'm used to . I also found out the truck is a Macho hiding under the primer so I'm excited about that
