New
Hey everyone I'm new to this site and new to the mopar world. I have a 74 duster with a 318 in it now and I'm currently build up a 360 for it hope it works out.
welcome to the forum and welcome to Mopar good luck on your build
Thanks. Do anyone have any ideas on a 360 build I was thing of running 10:1 compression with a comp cam magnum cam part # 20-232-4 an edelbrock air gap intake manifold , edelbrock heads and a 2500 stall converter with 355 gears and a 625 carter afb on 91 pumped gas any insight
What is the main goal for the car? Daily Driver? Weekend Warrior? Street/Strip Machine? Race Only? |
Weekend warrior
Welcome to the Forum.... Be sure to check out the Mopar of the Month contest.....
I would go with some J heads. And have them ported and polished. Or some X heads if you can find some for a good deal. But in most cases you can buy a set of aluminum heads for the same price or cheaper than you can get a pair of X heads for. As far as cam goes I'd figure out what heads and intake your going to run then ask some of these guys what a good cam to go with them would be.... Heads and cam will be the biggest most power adding factor of the engine. The magnum heads are supposed to be really good as well.
Bottom end you'll probably be find with stock crank and rods, get some flat top pistons and have the block milled to be flush with the pistons at top dead center. |
| All times are GMT -7. The time now is 04:10 AM. |
