Mopar Forums (/forums/)
-   -   Newbie from sweden needs help (https://moparforums.com/forums/f4/newbie-sweden-needs-help-1692/)
valiant70 Oct 27, 2008 01:46 PM
First of all Hello to everybody
Now to my problem.
I have a Plymouth Valiant 70 and i have a question about the brakes on it.
Front brakes are disks and back brakes are drums.
Is it original with disks in the front?
Or is it original with drums both in front and in the back?
Having problem to find new brakes you know:(
Excuse my bad english.
67 GTX Oct 27, 2008 02:12 PM
you could look on the fender tag to find out
valiant70 Oct 27, 2008 02:24 PM
Fender tag?
Its at the back somewhere right hehe
67 GTX Oct 27, 2008 02:37 PM
it should be on the drivers side fender in the engine compartment
valiant70 Oct 27, 2008 02:45 PM
aha do you mean the tag with all the numbers? Where i can see what colour the car is.
But how do i translate those numbers in to words?
I know they explained how to translate the numbers in that show overhaulin but i dont have a frigiin idea.
67 GTX Oct 27, 2008 03:00 PM
go on google, type in your car and fender tag numbers, and translate it
if it doesnt come up, just keep trying different word combinations
i know there is a site for this, but i cant remember what it is
valiant70 Oct 27, 2008 03:40 PM
ok thx very much
I will try this
67 GTX Oct 27, 2008 04:18 PM
np
let me know how it turns out
ef8340 Oct 27, 2008 04:29 PM
hi val
easy way to tell is it the 5 on 4 inch bolt circle rim if so it might be stock disc brakes which would be a kelsey/hayes brake 4 piston caliper if it has a 5 on 4 1/2 bolt circle rim your brakes have been upgraded to disc and larger bolt circle rim if so try getting parts for a 73 dart,duster,scamp with disc brakes. a fender tag isnt going to tell you much for disc brakes the build sheet will though then you'll need a book to read the option codes same with the fender tag
goodluck val
p.s your car came from the factory with a 5 on 4 inch bolt circle being a 70 valiant -a-body they didnt switch over to a large bolt pattern until 73 w/ a v/8 73's also had small pattern with a /6 hope this helps
Terry
valiant70 Oct 28, 2008 04:49 AM
Terry
So do you mean that my car had discs in the front when it roled out of the factory?
I was out meassured it and i got 5*10,5cm
And you said 5 on 4 inch bolt
There were also spacer plates on the car. My valiant brakes uneven in the front, could the spacers be a reason to this?
4 inches = 10,2 and i just meassured it quickly so i assume that i have 5 on 4 inch bolt.
Does anyone of you guys know where i can order new discs/brakes from?
Its very hard to find in sweden.
Commando Oct 28, 2008 09:58 AM
I can send you some if you know what you want, from my friend's part store.
valiant70 Oct 28, 2008 10:22 AM
If you would like you could check the price for new discs/complete brake system and what it would cost to ship it to sweden.
78D200 Oct 28, 2008 10:33 AM
http://store.summitracing.com/egnsea...115+4294922533
Hopefully this helps. By the looks of the products offered, I would say it came with drums all around.
valiant70 Oct 28, 2008 10:44 AM
Ooo thx
If anyone got anymore links just post them here
Commando Oct 28, 2008 11:18 AM
If you find a part number for what you want I will cross check it and see if I can get you a better deal. Then I can check USPS's website to see what it would cost from NJ to Sweden.
ef8340 Oct 28, 2008 04:23 PM
hi val
im kinda lost on the cm part without a ruler in front of me but with you saying it has spacer plates on it im asuming its a 5 on 4 another way to kinda dertermine this is looking at the caliper does it have 2 round humps on the top inner and outer sides of it and hard metal brake lines going to each side [ inner & outer] the spacer plates wont cause it to brake funny one of the pistons inside of the caliper will as for replacing them i think it might be cheaper to rebuild them if possible a place over here in the states called year one in brasselton georgia carries restoration parts , seeing how your wanting to replace them dissassemble one and see if it can be rebuilt 1st [ the caliper that isnt the one pulling while braking ] atleast to check for pitting or worn cups and seals yearone also has a catalog for a-bodies [valiant,dart, etc etc ] you can give them a call at 1-800-year-one and tell them you need a catalog for your car atleast to do a price check on your parts seeing as how your over seas
good luck either way
Terry
valiant70 Oct 29, 2008 03:10 AM
Thx very much for all help.
Maybe i have found a place here in sweden for parts :)
I will give them a call first, since its a "little" bit closer hehe
But i am very happy that i found this forum because im new to this type of cars and i need all the help i can get when i find new problems on the car.
Take care all of you and i will post here if i fix the problem.
If you wanna se my car heres a link
http://img401.imageshack.us/img401/1...tsonjg3.th.jpghttp://img401.imageshack.us/images/thpix.gif
Commando Oct 29, 2008 05:01 AM
Nice picture, looks real nice.
valiant70 Oct 29, 2008 08:01 AM
Thx i try to keep it shiny :)
78D200 Oct 29, 2008 01:16 PM
That would make one hell of a sleeper! looks nice.
challenger Oct 29, 2008 07:15 PM
Sweet looking ride and welcome to the forums Valiant70 and here are a few places you can look into and they will tell you almost anything about your car if you have all the numbers , enjoy the help you may ask :D Mopar VIN Decoder , Mopar Casting Numbers - MyMopar.com - Mopar Part Numners , Mopar Casting Numbers - MyMopar.com - Mopar Part Numners
challenger Oct 29, 2008 07:17 PM
sorry about the double sites but my computer has been acting up for a few days :(
valiant70 Oct 31, 2008 11:17 AM
Hahah The brakes past the veichle inspection hahaha But there was a few other problems but nothing big. Thank for all help guys
67 GTX Oct 31, 2008 04:45 PM
what are the other problems?
valiant70 Oct 31, 2008 05:14 PM
1. The hinge on one of the doors needs to be replaced.
2. Both brake lights dont work.
3. The car releases to much "exhaust?" "Swedish laws suck hehe"
4. The handbrake dont brake on rear right wheel.
Ive already talked to a mechanic/workshop and they will fix it on november 12.
But maybe some of you guys knows about some known issues with the brake light and the handbrake?
If i can fix this my self it will be a lot cheaper.
But i rather pay for this instead of new front brake system:)
I bought new light bulbs for the tail lights today but still no brake light:( The tail lights work but when i brake nothing happens.
Is there some type of switch somewhere?
