rim width/tire width clearances
having difficulty finding oem specs for width/offset of wheels.
have not yet taken posession of vehicle already convinced 235R70 15 tires will fit with clearance ...but, am not sure if 15 x 8 wheels will be suitable as oem wheels were 14 x ? ... 6 ? (with zero offset, i've been informed), an increase from 6" (probable) to 8" wheel width will consume more well space.... Question : will it clear or not, if i put 15" x 8" rims mounted with 235 R70 15's ? |
It might help if we new what you have so one can try to figure out what you are saying.
user name
my user nsme is what i have
'65 dodge polara E1 full size 4 door hardtop sedan |
The tire size is not very large, I have a 60s vehicle with small rear wheel wells and they fit with 7" wheels. I would think it would completely depend on what offset the 8" wheels are.
thnx
the info given with my original inquiry includes
...zero offset. the tire itself does not concern me, except for how its positioning will be affected by using 8" wide wheels instead of 5 1/2" or 6" wide wheels (my unknown oem factor)...which will (w/ zero offset) take up 1" - 1 1/4" extra space in both positive & negative directions. both the centerline & the sidewall vertical tangent plane of the tires will remain the same, but what i dont know is, if the interior surface of the wheel, outside of where tire bead seats, will have sufficient clearance....say from ...for example, the shock/shock mounting pad if i had posession of the vehicle already, i would simply look & measure. but i dont yet, & for now i am preplanning potential upgrades. Nonetheless, Thank You...your feedback is appreciated. |
clear
15 x 8's
235R65 both front & rear, tightest clearances are 3/8" restoration/upgrades have been underway for 4 weeks |
