Mopar Forums (/forums/)
-   -   tire size (https://moparforums.com/forums/f4/tire-size-10991/)
plymouthrocks Oct 31, 2011 06:38 PM
tire size
Hello. I am new to this forum and was wondering if anyone out there would know if a 215/60/15 will fit a 70 Cuda. Thanks
Silverick Oct 31, 2011 08:35 PM
It would depend on the wheel and offset. A 215/60/15 is not a very big tire and on a stock offset wheel, I don't see any problem.
Welcome to the forum!
plymouthrocks Nov 1, 2011 08:16 AM
thanks
Thanks Silverick. It is a stock rim and if that will fit no problem I might even go 225. Thanks again.:)
rickyr Nov 1, 2011 09:29 AM
[QUOTE=Silverick;77136]It would depend on the wheel and offset. A 215/60/15 is not a very big tire and on a stock offset wheel, I don't see any problem.
X2
and welcome to the forum :hello:
John Van Nov 1, 2011 06:29 PM
Had a set of 235/60/15's on the front lot's of room!
john
plymouthrocks Nov 2, 2011 08:48 AM
thanks
I app. the info. Thankyou much.
challenger Nov 3, 2011 06:52 PM
Welcome hope you stick around :hello:
MReeves Nov 4, 2011 04:08 AM
Welcome to the forum... Glad to have you... Be sure to check out the Mopar of the month contest... See the sticky for the simple rules and then next month you can help pick the winner...
78D200 Nov 24, 2011 03:02 AM
rdrunner1974 Nov 24, 2011 07:03 AM
Tires
FYI: 70's on the front make for better steering. Check this link for tire size, may be helpfull to you.
http://www.1010tires.com/tiresizecalculator.asp :argue:
