rearend 67 belvedere
my car has 8.75 rearend and a built 440, the previous owner has broken the gear 3 times he also informed they were not cheap gears as that was my first thought,he suggested i get a diffrent rear end "dana" not sure how much but i know they are expensive. does anyone have any other ideas besides the swap?
we broke the last one while test driving rolling around 30 and stomped it, thanks in advance! |
What brand are the gears? What ratio? What was the backspacing set to? Pinion bearing pre-load? What did the pattern look like?
If the gears are not setup proper and a good pattern is run, also if they are not broken in, you can damage them to the point of breaking them. |
Chysler put the 8 3/4 rear behind 426 Hemi Automatics so they are quite stout. The Dana was used behind 4 speed 440s and 426 Hemis. Danas are heavier and more difficult to change gear ratios in. With the 8 3/4 it as simple as changing out the pumpkin where as the Dana 60 is like a GM and must be set up in the case every time you change gear ratios. Unless you have a high HP 4 speed, I would stay with the 8 3/4. I have had BB mopars since the 70s and have only had 1 problem with a 8 3/4 and that was bearing Noise(Howl).
what case is in the 8 3/4?
You may just have a weak one. The 8 3/4 is strong enough, the dana is not needed. |
Originally Posted by my1stmopar
(Post 63354)
thanks folks for the quick response i will get more info from previous owner on the gears and things tomorrow, sounds promising was not looking forward to the swap. thanks again for your help and patience!
found a axle stamped 741 and 3.23 gears and he toll me it was a 8 3/4 out of a 1964 belvedere is there such a thing
Originally Posted by duckboat55
(Post 158808)
thanks |
| All times are GMT -7. The time now is 07:04 AM. |
