turn signals
Old Jun 7, 2009 | 11:22 AM
67Polara's Avatar
turn signals
i'm having problems with my left turnsignal. the lights come on but it dsnt flash... any ideas?
Old Jun 7, 2009 | 11:39 AM
Polaradude's Avatar
Your flasher is probably toast.
Old Jun 7, 2009 | 02:10 PM
67Polara's Avatar
so what should i do to see if thats causing my problem ?
Old Jun 7, 2009 | 02:21 PM
Polaradude's Avatar
Well, if you can't hear the flasher working when you activate the turn signal, replace the flasher.
Old Jun 7, 2009 | 05:01 PM
67Polara's Avatar
like the bulb it's self ?
Old Jun 8, 2009 | 06:16 AM
theomahamoparguy's Avatar
no, there is a flasher unit under the dash, usually in the vicinity of the fuse block. It is a round, sort of cylindrical looking thing, silver in color about 1 1/2 inch diameter maybe 1 or 2 inches long, It just unplugs from its holder/connector.
Old Jun 8, 2009 | 06:29 AM
One problem that people dont realize is that the flasher work off of electrical resistance of the bulb itself. So, you must have the correct bulb in the socket and the bulb socket must be in good condition for the flasher to work correctly. One alternative is to use a electronic flasher unit instead of the original resistance type. [originally intended for LED lights that have little to no resistance]. These types do not rely on the resistance in the circuit. Any auto parts store or truck stop has them.
Anyway, just make sure you have the correct bulb in there first.
Old Jun 8, 2009 | 12:18 PM
67Polara's Avatar
i've checked the bulbs they all work. so id have to get a flasher unit ?
Old Jun 8, 2009 | 02:08 PM
Polaradude's Avatar
Like I said before if you can't hear it replace it.
lifted150
Apr 8, 2022 07:09 PM
JP67
Aug 17, 2012 07:34 PM
JETBLU
Aug 8, 2012 10:58 PM
JP67
May 10, 2012 03:42 PM
johnnyc
Mar 4, 2008 06:13 AM
