Mopar Forums (/forums/)
-   K-Cars (https://moparforums.com/forums/f45/)
-   -   1990 Dynasty Odometer Problem (https://moparforums.com/forums/f45/1990-dynasty-odometer-problem-19223/)
jrbuzz 03-04-2016 12:56 PM
Hello! I own a 1990 Dodge Dynasty with 74k miles and one day, while I was driving, I noticed the odometer had stopped working, as well as the trip odometer, but all the other gauges were fine. I looked up how to repair it and replaced the two small plastic gears that are prone to breaking and causing this issue. I took it out for a drive the other day after installing the speedometer unit again and found that it still did not work. I plan to take it apart again and make sure I got allot the broken teeth from the previous gears out, but when I manually turned the odometer forward, it worked just fine. What else could be causing the problem?
moparted 03-05-2016 01:45 AM
step up motor in cluster
jrbuzz 03-05-2016 07:54 AM
I'm assuming that's the motor that turns the gears. Where can I get a replacement? If I can get a new one rather than one that's already been beaten to death, that would be better.
oldman 03-09-2023 03:08 PM
If I remember correctly there is no speedometer cable. If that is the case you need a vehicle speed sensor. They should be available at any parts store.
