Jacking 93 LeBaron
Hope this is the right spot, looks pretty quiet.
I need to change both rear rims. Can I use the center of the rear axle as a jack point to lift the whole back up at once? It looks solid enough, but it doesn't hurt to check. :confused: Thanks, Gary |
IIRC, They are FWD... could be wrong.
you need to jack one side up at a time. There are lift points (the frame, or a thicker metal piece) for jacking the car up. Always use jack stands. Iknow its a dead thread, but it'll help others out in the future. |
| All times are GMT -7. The time now is 06:07 AM. |
