memory front seat for 2010 town&country
I Have a 2010 town&county without front memory power seat, seat has power & heat. What is needed to put one in? I all ready have a power&heated seat.
bemill
bemill
Probably nothing but the correct seat from the bone yard..
Most new car harnesses are set up for every accessories. Plug and play..
Look under the seat for an unused female receptacle. Be careful when you pull the seat there is a sensor in there for the airbag and don't stretch the connection. Use a tool to open it.
Also look in fuse box and there will be a spot for power seats. It will be open bay. Make sure there is 12v on one side at the box.
Then get your seat.
If you have no power get the seat and start a new thread. We can walk you thru the wiring.
Then get your seat.
bemill (03-18-2012)
Aside from the DMSM module, you have to configure the TIPM to accept this module, and unfortunately that is something that can only be done with CDS software from Chrysler engineering. If you plug it in, every other module with throw a code for an unrecognized module on the Bus. It won't work and you'll have codes. The build config is specific to each vehicle and the TIPM is programmed for that config only. Sorry.
bemill (04-14-2012)
bundu
02-11-2015 01:52 PM
Rumblefish318
07-27-2013 09:07 PM
