Mopar Forums (/forums/)
-   Performance parts and engine development (https://moparforums.com/forums/f57/)
-   -   360 carberated cheap build up (https://moparforums.com/forums/f57/360-carberated-cheap-build-up-9340/)
dodge6890 04-24-2011 09:29 AM
i have a 360 motor in a dodge sportsman camper that im looking to get a little more power out of without spending to much money in the process.
TVLynn 04-25-2011 12:21 AM
Maybe headers and a good 4bbl carb do you have a 2 bbl or the thermoquad manifold?
Stick with a dual plane intake, 600 cfm carb and a mild cam something like 268 degree
78D200 04-25-2011 02:41 AM
If you don't want to tear into the motor too much, then go with a 4barrel carb, intake manifold, headers, Sure Grip in the rear axle and possibly a HD shift kit for the tranny (Assuming its an auto).
PK1 12-28-2011 05:55 PM
Another vote for Headers for sure. Get Tri-y style to get the biggest bang for the buck out of a lower RPM motor. Then a quality aluminum dual plane and a carb.
Coronet 500 12-28-2011 06:10 PM
If it's a stock distributor a recurve and controling your initial advance could help for almost no money. Lots of info on the subject if you look.
bboogieart 01-22-2012 09:58 AM
Are you leaving it in the motor home? Mine came with super long tube headers. I will be pulling it for something else and using the headers in my van. It also had a 2 bbl. The thermoquad would be better.
The earlier posts said it all, I really can't add much. Maybe this might help. Depending on where you live, I have found that many junk yards out in the rural areas still have some older stuff laying around and a little yard searching can be fun and yeild many good parts. I recently got a windsheild ( 70's p/u) a 4 bbl intake (318 dakota) and a pair of rims (14" five slot off the same dakota) for 50 bucks.
