NHRA Northwest Nats Seattle
Fri, 5 Aug 2011, 05:26 PM
http://www.dragracecentral.com/image...00_leftdot.gif Pro Stock Qualifying Notes, Session #1 By Rick Green http://www.dragracecentral.com/image...00_leftdot.gif http://www.dragracecentral.com/images/small_print.gif KENT, Wash. - Notes from round 1 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 24th annual O'Reilly Auto Parts NHRA Northwest Nationals listing lane, driver name, elapsed time, top speed, and position in order following run: Right Lane: Warren Johnson Runs 6.696/206.67, Now #1 Weather conditions: air temperature 69 degrees, relative humidity 60 percent, barometer 29.76 inches, adjusted altitude 1,477 feet, track temperature 88 degrees. WJ made a quick move toward the centerline, but reeled it in. Warren Johnson's incremental times: 60ft-0.986 sec., 330ft-2.786, 660ft-4.301/162.57 mph, 1,000ft-5.603. Left Lane: Kurt Johnson Runs 11.469/75.58, Now #3 Right Lane: V. Gaines Runs 6.624/209.92, Now #1 Johnson with problems right off the starting line and pushed in the clutch. Gaines will a little tire spin, but got it to hook up...V. Gaines' incremental times: 60ft-1.004 sec., 330ft-2.796, 660ft-4.278/166.29 mph, 1,000ft-5.551. Left Lane: Ronnie Humphrey Runs 6.553/210.80, Now #1 Right Lane: Larry Morgan Runs 6.579/210.01, Now #2 This was a good drag race...Humphrey with a great pass and sets the track E.T. record. Ronnie Humphrey's incremental times: 60ft-0.981 sec., 330ft-2.746, 660ft-4.216/167.22 mph, 1,000ft-5.483. Larry Morgan's incremental times: 60ft-0.983 sec., 330ft-2.758, 660ft-4.233/166.50 mph, 1,000ft-5.506. Left Lane: Ron Krisher Runs 6.592/210.54, Now #3 Right Lane: Shane Gray Runs 18.043/69.47, Now #7 Gray shook right off the starting line and clicked it off. Krisher with a good pass to start the weekend. Ron Krisher's incremental times: 60ft-0.988 sec., 330ft-2.765, 660ft-4.247/166.17 mph, 1,000ft-5.520. Left Lane: Rodger Brogdon Runs 6.545/210.67, Now #1 Right Lane: Erica Enders Runs 6.571/210.60, Now #3 The National record holders...Erica has the speed record holder and Brogdon with the E.T. record. Brogdon with a great pass to go to the number one spot, and sets the track record. Rodger Brogdon's incremental times: 60ft-0.977 sec., 330ft-2.738, 660ft-4.208/167.38 mph, 1,000ft-5.475. Enders with a real nice pass to go to the number three spot. Erica Enders' incremental times: 60ft-0.994 sec., 330ft-2.761, 660ft-4.235/167.24 mph, 1,000ft-5.502. Left Lane: Greg Stanfield Runs 6.576/209.43, Now #5 Right Lane: Allen Johnson Runs 6.564/211.16, Now #3 Johnson with a good pass to go to the number three spot. Allen Johnson's incremental times: 60ft-0.988 sec., 330ft-2.754, 660ft-4.228/166.89 mph, 1,000ft-5.496. Stanfield gets into the top half of the show with a good pass. Greg Stanfield's incremental times: 60ft-0.984 sec., 330ft-2.751, 660ft-4.227/166.60 mph, 1,000ft-5.501. Left Lane: Vincent Nobile Runs 6.574/210.31, Now #6 Right Lane: Greg Anderson Runs 6.556/210.93, Now #3 Anderson goes to the number three spot with a real nice pass. Greg Anderson's incremental times: 60ft-0.989 sec., 330ft-2.753, 660ft-4.222/167.49 mph, 1,000ft-5.487. Nobile gets into the top half of the show. Vincent Nobile's incremental times: 60ft-0.971 sec., 330ft-2.760, 660ft-4.228/166.15 mph, 1,000ft-5.502. Left Lane: Jason Line Runs 6.548/210.57, Now #2 Right Lane: Mike Edwards Runs 6.563/210.47, Now #5 Line with a great pass to go to the number two spot and the Summit cars ar two, three and four. Jason Line's incremental times: 60ft-0.972 sec., 330ft-2.738, 660ft-4.210/167.12 mph, 1,000ft-5.478. Edwards with a real nice pass to go to the number five spot. Mike Edwards' incremental times: 60ft-0.974 sec., 330ft-2.745, 660ft-4.222/166.83 mph, 1,000ft-5.493. Timing data courtesy of CompuLink http://www.dragracecentral.com/image...t_endstory.gif From DragRaceCentral.com |
Round 2 Qualifying
Fri, 5 Aug 2011, 08:14 PM
http://www.dragracecentral.com/image...00_leftdot.gif Pro Stock Qualifying Notes, Session #2 By Rick Green http://www.dragracecentral.com/image...00_leftdot.gif http://www.dragracecentral.com/images/small_print.gif KENT, Wash. - Notes from round 2 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 24th annual O'Reilly Auto Parts NHRA Northwest Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run: Left Lane: Shane Gray Runs 15.059/55.56, Now #15; Best prior run: 18.043/69.47, Was #15 Gray spun the tires hard and the car was side ways before he lifted. Left Lane: Warren Johnson Runs 6.565/210.41, Now #7; Best prior run: 6.696/206.67, Was #13 Right Lane: Kurt Johnson Runs 6.592/210.05, Now #13; Best prior run: 11.469/75.58, Was #14 WJ with a good short time and he gets in the show. Warren Johnson's incremental times: 60ft-0.972 sec., 330ft-2.743, 660ft-4.221/166.68 mph, 1,000ft-5.493. Kurt Johnson improves, but not enough to get in the show. Kurt Johnson's incremental times: 60ft-0.977 sec., 330ft-2.755, 660ft-4.241/165.62 mph, 1,000ft-5.518. Left Lane: V. Gaines Runs 6.564/210.77, Now #7; Best prior run: 6.624/209.92, Was #14 Right Lane: Ron Krisher Runs 6.597/209.98, Now #13; Best prior run: 6.592/210.54, Was #12 No help here for Krisher...Gaines improves and goes to the number seven spot. V. Gaines' incremental times: 60ft-0.986 sec., 330ft-2.752, 660ft-4.225/167.12 mph, 1,000ft-5.494. Left Lane: Larry Morgan Runs 12.214/69.65, Now #12; Best prior run: 6.579/210.01, Was #12 Right Lane: Greg Stanfield Runs 6.605/210.08, Now #11; Best prior run: 6.576/209.43, Was #11 Morgan spun the tires hard right off the starting line and clicked it off. No help here for Stanfield. Left Lane: Erica Enders Runs 6.555/210.41, Now #4; Best prior run: 6.571/210.60, Was #9 Right Lane: Vincent Nobile Runs 6.602/210.21, Now #10; Best prior run: 6.574/210.31, Was #10 Enders launched hard and keep it hooked up and moved into the top half of the show. Erica Enders' incremental times: 60ft-0.978 sec., 330ft-2.746, 660ft-4.218/167.32 mph, 1,000ft-5.486. No help here for Nobile. Vincent Nobile's incremental times: 60ft-0.986 sec., 330ft-2.765, 660ft-4.250/165.76 mph, 1,000ft-5.527. Left Lane: Allen Johnson Runs 6.568/210.77, Now #7; Best prior run: 6.564/211.16, Was #7 Right Lane: Ronnie Humphrey Runs 6.576/210.64, Now #3; Best prior run: 6.553/210.80, Was #3 No help here for either driver...Allen Johnson's incremental times: 60ft-0.977 sec., 330ft-2.744, 660ft-4.222/166.64 mph, 1,000ft-5.496. Ronnie Humphrey's incremental times: 60ft-0.986 sec., 330ft-2.761, 660ft-4.236/166.79 mph, 1,000ft-5.505. Left Lane: Mike Edwards Runs 6.541/210.97, Now #1; Best prior run: 6.563/210.47, Was #6 Right Lane: Jason Line Runs 6.547/211.03, Now #3; Best prior run: 6.548/210.57, Was #2 Edwards with a great short time and parlays that into the number one spot. Mike Edwards' incremental times: 60ft-0.968 sec., 330ft-2.733, 660ft-4.205/167.38 mph, 1,000ft-5.473. Line improves, but will stay in the number three spot. Jason Line's incremental times: 60ft-0.982 sec., 330ft-2.743, 660ft-4.212/167.51 mph, 1,000ft-5.479. Left Lane: Greg Anderson Runs 6.541/211.16, Now #1; Best prior run: 6.556/210.93, Was #6 Right Lane: Rodger Brogdon Runs 6.567/210.28, Now #3; Best prior run: 6.545/210.67, Was #2 No help here for Brogdon, but still a good pass. Rodger Brogdon's incremental times: 60ft-0.991 sec., 330ft-2.755, 660ft-4.227/167.18 mph, 1,000ft-5.496. Anderson with a great looking pass and ties Edwards E.T. and will get the number one spot based on his faster speed. Greg Anderson's incremental times: 60ft-0.971 sec., 330ft-2.736, 660ft-4.205/167.41 mph, 1,000ft-5.473. He ties Allen Johnson for top speed of the event... Timing data courtesy of CompuLink From DragRaceCentral.com |
Round 3 Qualifying
Sat, 6 Aug 2011, 02:34 PM
http://www.dragracecentral.com/image...00_leftdot.gif Pro Stock Qualifying Notes, Session #3 By Rick Green http://www.dragracecentral.com/image...00_leftdot.gif http://www.dragracecentral.com/images/small_print.gif KENT, Wash. - Notes from round 3 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 24th annual O'Reilly Auto Parts NHRA Northwest Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run: Right Lane: Shane Gray Runs 17.474/82.36, Now #13; No Prior Run Weather conditions: air temperature 70 degrees, relative humidity 62 percent, barometer 29.73 inches, adjusted altitude 1,591 feet, track temperature 84 degrees. Gray with violent tire shake as soon as he let the clutch out and pushed it right back in. Left Lane: Greg Stanfield Runs 26.856/57.15, Now #11; Best prior run: 6.576/209.43, Was #11 Right Lane: Larry Morgan Runs 6.687/209.01, Now #12; Best prior run: 6.579/210.01, Was #12 Stanfield with a lot tire spin as soon the light turned green and he clicked it off. Morgan was straight down the groove, but doesn't improve. Larry Morgan's incremental times: 60ft-1.037 sec., 330ft-2.845, 660ft-4.328/165.50 mph, 1,000ft-5.608. Left Lane: Vincent Nobile Runs 6.583/210.21, Now #10; Best prior run: 6.574/210.31, Was #10 Right Lane: Allen Johnson Runs 6.543/211.69, Now #3; Best prior run: 6.564/211.16, Was #7 Nobile with another good looking pass, but will not improve. Johnson with a great pass to move up to the number three spot and sets top speed of the event and the track speed record. Allen Johnson's incremental times: 60ft-0.985 sec., 330ft-2.744, 660ft-4.213/167.47 mph, 1,000ft-5.478. Left Lane: Ron Krisher Runs 25.124/24.33, Now #14; No Prior Run Right Lane: Warren Johnson Runs 6.569/210.41, Now #9; Best prior run: 6.565/210.41, Was #9 Krisher spins the tires right at the hit and pushes the clutch in. Johnson is just a few ticks slower than yesterday's pass so he will stay in the number nine spot. Warren Johnson's incremental times: 60ft-0.974 sec., 330ft-2.746, 660ft-4.223/166.50 mph, 1,000ft-5.496. Left Lane: Kurt Johnson Runs 6.577/210.47, Now #12; No Prior Run Right Lane: V. Gaines Runs 6.586/210.64, Now #8; Best prior run: 6.564/210.77, Was #8 Gaines with a good pass, but slows from his time from yesterday. V. Gaines' incremental times: 60ft-0.992 sec., 330ft-2.768, 660ft-4.244/166.83 mph, 1,000ft-5.515. Johnson with his quickest pass of the weekend and goes to the number 12 spot. Kurt Johnson's incremental times: 60ft-0.977 sec., 330ft-2.752, 660ft-4.232/166.15 mph, 1,000ft-5.505. Left Lane: Ronnie Humphrey Runs 6.581/209.98, Now #6; Best prior run: 6.553/210.80, Was #6 Right Lane: Erica Enders Runs 6.603/208.36, Now #7; Best prior run: 6.555/210.41, Was #7 Neither driver improves, but still a couple good passes. Ronnie Humphrey's incremental times: 60ft-0.994 sec., 330ft-2.763, 660ft-4.237/166.60 mph, 1,000ft-5.508. Erica Enders' incremental times: 60ft-0.986 sec., 330ft-2.760, 660ft-4.243/165.48 mph, 1,000ft-5.524. Left Lane: Rodger Brogdon Runs 6.573/210.44, Now #4; Best prior run: 6.545/210.67, Was #4 Right Lane: Mike Edwards Runs 6.550/210.83, Now #2; Best prior run: 6.541/210.97, Was #2 Neither driver improves, but Edwards with the second quickest pass of the round. Mike Edwards' incremental times: 60ft-0.972 sec., 330ft-2.738, 660ft-4.212/167.07 mph, 1,000ft-5.481. Brogdon with a good looking pass. Rodger Brogdon's incremental times: 60ft-0.988 sec., 330ft-2.761, 660ft-4.235/167.16 mph, 1,000ft-5.503. Left Lane: Jason Line Runs 6.538/211.06, Now #2; Best prior run: 6.547/211.03, Was #5 Right Lane: Greg Anderson Runs 6.536/211.26, Now #1; Best prior run: 6.541/211.16, Was #1 This was a great drag race by the Summit cars with Anderson improving on his number one qualifying time. Greg Anderson's incremental times: 60ft-0.975 sec., 330ft-2.733, 660ft-4.202/167.41 mph, 1,000ft-5.468. That is the track E.T. record. Line goes to the number two spot with a great pass. Jason Line's incremental times: 60ft-0.969 sec., 330ft-2.735, 660ft-4.204/167.18 mph, 1,000ft-5.471. Timing data courtesy of CompuLink http://www.dragracecentral.com/image...t_endstory.gif From DragRaceCentral.com |
Final Qualifying
Sat, 6 Aug 2011, 05:16 PM
http://www.dragracecentral.com/image...00_leftdot.gif Pro Stock Qualifying Notes, Final Session By Rick Green http://www.dragracecentral.com/image...00_leftdot.gif http://www.dragracecentral.com/images/small_print.gif KENT, Wash. - Notes from final, round 4 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 24th annual O'Reilly Auto Parts NHRA Northwest Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run: Left Lane: Shane Gray Runs 6.634/207.53, Now #14; Best prior run: 17.474/82.36, Was #14 Weather conditions: air temperature 72 degrees, relative humidity 58 percent, barometer 29.73 inches, adjusted altitude 1,769 feet, track temperature 84 degrees. Gray with his first full pass of the weekend. Left Lane: Larry Morgan Runs 6.633/208.91, Now #13; Best prior run: 6.579/210.01, Was #13 Right Lane: Ron Krisher Runs 7.483/130.68, Now #15; Best prior run: 25.124/24.33, Was #15 Krisher with problems again...Morgan is straight down the groove. Larry Morgan's incremental times: 60ft-0.990 sec., 330ft-2.788, 660ft-4.273/165.31 mph, 1,000ft-5.555. Left Lane: Warren Johnson Runs 6.582/209.52, Now #9; Best prior run: 6.565/210.41, Was #9 Right Lane: Kurt Johnson Runs 7.032/156.19, Now #12; Best prior run: 6.577/210.47, Was #12 WJ with a good clean pass...Kurt Johnson slows on the top end. Left Lane: V. Gaines Runs 6.579/210.01, Now #8; Best prior run: 6.564/210.77, Was #8 Right Lane: Greg Stanfield Runs 6.603/209.46, Now #11; Best prior run: 6.576/209.43, Was #11 Gaines with another good pass...V. Gaines' incremental times: 60ft-0.976 sec., 330ft-2.750, 660ft-4.231/166.07 mph, 1,000ft-5.506. Stanfield with a good pass...Greg Stanfield's incremental times: 60ft-0.994 sec., 330ft-2.785, 660ft-4.250/166.27 mph, 1,000ft-5.526. Left Lane: Erica Enders Runs 6.544/210.67, Now #5; Best prior run: 6.555/210.41, Was #7 Right Lane: Vincent Nobile Runs 6.601/209.59, Now #10; Best prior run: 6.574/210.31, Was #10 Nobile with a good pass...Vincent Nobile's incremental times: 60ft-0.988 sec., 330ft-2.766, 660ft-4.248/165.78 mph, 1,000ft-5.524. Enders launched hard and runs her quickest pass of the weekend to move up the ladder. Erica Enders' incremental times: 60ft-0.966 sec., 330ft-2.730, 660ft-4.200/167.26 mph, 1,000ft-5.472. Left Lane: Allen Johnson Runs 6.556/210.97, Now #4; Best prior run: 6.543/211.69, Was #4 Right Lane: Ronnie Humphrey Runs 6.584/210.01, Now #7; Best prior run: 6.553/210.80, Was #7 Humphrey with a clean pass...Ronnie Humphrey's incremental times: 60ft-0.991 sec., 330ft-2.761, 660ft-4.239/166.44 mph, 1,000ft-5.512. Johnson with the second quickest pass of the round. Allen Johnson's incremental times: 60ft-0.971 sec., 330ft-2.753, 660ft-4.218/166.95 mph, 1,000ft-5.487. Left Lane: Mike Edwards Runs 6.545/210.83, Now #3; Best prior run: 6.541/210.97, Was #3 Right Lane: Rodger Brogdon Runs 6.575/210.08, Now #6; Best prior run: 6.545/210.67, Was #6 Edwards with the second quickest pass of the session and he will stay third. Mike Edwards' incremental times: 60ft-0.970 sec., 330ft-2.734, 660ft-4.206/167.22 mph, 1,000ft-5.475. Brogdon with another good pass. Rodger Brogdon's incremental times: 60ft-0.986 sec., 330ft-2.753, 660ft-4.229/166.50 mph, 1,000ft-5.502. Left Lane: Greg Anderson Runs 6.546/210.73, Now #1; Best prior run: 6.536/211.26, Was #1 Right Lane: Jason Line Runs 6.540/211.20, Now #2; Best prior run: 6.538/211.06, Was #2 Line with the quickest pass of session...Jason Line's incremental times: 60ft-0.975 sec., 330ft-2.735, 660ft-4.205/167.28 mph, 1,000ft-5.472. Anderson with the fourth quickest pass of the session. Greg Anderson's incremental times: 60ft-0.975 sec., 330ft-2.736, 660ft-4.206/167.12 mph, 1,000ft-5.476. Anderson qualifies No. 1 for the 75th in his career. Timing data courtesy of CompuLink http://www.dragracecentral.com/image...t_endstory.gif From DragRaceCentral.com |
Summary of Eliminations
Sun, 7 Aug 2011, 09:50 PM
http://www.dragracecentral.com/image...00_leftdot.gif Summary of Eliminations in Pro Stock http://www.dragracecentral.com/images/small_print.gif KENT, Wash. - Summary of eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, 24th annual O'Reilly Auto Parts NHRA Northwest Nationals: Round 1: V. Gaines, Lakewood CO, '11 Avenger, Left lane, (0.033) 8.873 101.87 def. Warren Johnson, SugarHill GA, '09 GXP, (0.058) 12.479 75.24 Vincent Nobile, Dix Hills NY, '11 Avenger, Left lane, (0.014) 6.588 210.01 def. Ronnie Humphrey,Jacksonville NC, '09 GXP, (0.053) 6.604 210.18 Erica Enders, New Orleans LA, '10 Cobalt, Left lane, (0.026) 6.564 210.44 def. Kurt Johnson, SugarHill GA, '09 GXP, (0.008) 7.709 153.47 Greg Anderson, Mooresville NC, '09 GXP, Left lane, (0.032) 6.540 210.87 was unopposed Jason Line, Mooresville NC, '09 GXP, Left lane, (0.031) 6.531 211.06 def. Ron Krisher, Warren OH,'09 GXP, NT-Broke Before Staging Mike Edwards, Coweta OK, '09 GXP, Left lane, (0.039) 6.561 210.70 def. Shane Gray, Denver NC, '09GXP, (0.022) 6.593 209.30 Allen Johnson, Greeneville TN, '11 Avenger, Left lane, (0.041) 6.587 210.54 def. Larry Morgan,Newark OH, '11 Mustang, (0.040) 6.591 210.37 Rodger Brogdon, Tomball TX, '09 GXP, Left lane, (0.043) 6.583 209.49 def. Greg Stanfield, BossierCity LA, '09 GXP, (0.011) 7.085 153.20 Round 2: E Enders, Left lane, (0.015) 6.573 209.88 def. A Johnson, (0.004) 6.609 210.60 R Brogdon, Right lane, (0.020) 6.589 209.65 def. M Edwards, (0.044) 6.732 209.49 J Line, Right lane, (0.026) 6.561 210.60 def. V Nobile, (-0.005 foul) 6.598 209.92 G Anderson, Right lane, (0.044) 6.574 210.14 def. V Gaines, (0.041) 6.595 209.69 Round 3: G Anderson, Right lane, (0.045) 6.562 210.44 def. E Enders, (0.056) 6.570 210.18 J Line, Left lane, (0.024) 6.553 210.24 def. R Brogdon, (0.024) 6.586 209.62 Round 4: J Line, Left lane, (0.020) 6.553 210.87 def. G Anderson, (0.016) 6.567 211.13 Low ET: Jason Line 6.531 seconds Top Speed: Allen Johnson 211.69 MPH Timing data courtesy of CompuLink http://www.dragracecentral.com/image...t_endstory.gif From DragRaceCentral.com |
