Summit Racing Equipment NHRA Nationals Norwalk
Fri, 25 Jun 2010, 06:00 PM
Pro Stock Qualifying Notes, Session #1
By Rick Green
NORWALK, Ohio - Notes from round 1 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, Fourth annual Summit Racing Equipment NHRA Nationals listing lane, driver name, elapsed time, top speed, and position in order following run:
Left Lane: Jim Cunningham Runs 13.881/60.98, Now #2
Right Lane: Bob Benza Runs 6.750/204.17, Now #1
Weather conditions: air temperature 79 degrees, relative humidity 53 percent, barometer 29.10 inches, adjusted altitude 2,972 feet, track temperature 124 degrees.
Cunningham was real loose right off the starting line and clicked it off. Benza with a clean pass to start the weekend.
Left Lane: John Gaydosh Jr Runs 6.902/199.49, Now #3
Right Lane: Erica Enders Runs 6.730/204.91, Now #1
Enders at her first race since Chicago and she is straight down the groove with a nice pass. Gaydosh Jr. with a clean pass.
Left Lane: Justin Humphreys Runs 6.686/206.67, Now #1
Right Lane: Vinnie Deceglie Runs 6.692/206.80, Now #2
Humphreys with a great looking pass as he goes to the number one spot. Justin Humphreys' incremental times: 60ft-0.993 sec., 330ft-2.797, 660ft-4.300/163.69 mph, 1,000ft-5.595. Deceglie with a good looking pass to start the weekend. Vinnie Deceglie's incremental times: 60ft-1.008 sec., 330ft-2.811, 660ft-4.310/164.49 mph, 1,000ft-5.602.
Left Lane: Larry Morgan Runs 6.693/206.80, Now #4
Right Lane: V. Gaines Runs 6.661/207.40, Now #1
Gaines was straight down the groove to the number one spot. V. Gaines' incremental times: 60ft-0.995 sec., 330ft-2.793, 660ft-4.288/164.95 mph, 1,000ft-5.576. Morgan with a good pass...Larry Morgan's incremental times: 60ft-1.005 sec., 330ft-2.809, 660ft-4.309/164.37 mph, 1,000ft-5.603.
Left Lane: Kurt Johnson Runs 14.616/57.73, Now #10
Right Lane: Warren Johnson Runs 6.691/207.02, Now #3
Kurt make a quick move toward the centerline and clicked it off. Warren with a nice pass to go to the number three spot. Warren Johnson's incremental times: 60ft-0.995 sec., 330ft-2.802, 660ft-4.306/163.81 mph, 1,000ft-5.601.
Left Lane: Bob Yonke Runs 6.688/206.76, Now #4
Right Lane: Johnny Gray Runs 6.677/207.56, Now #2
Gray was straight down the groove into the number two spot...Johnny Gray's incremental times: 60ft-1.000 sec., 330ft-2.805, 660ft-4.302/164.53 mph, 1,000ft-5.591. Yonke with a good clean pass to go to the number four spot. Bob Yonke's incremental times: 60ft-0.997 sec., 330ft-2.800, 660ft-4.302/163.87 mph, 1,000ft-5.597.
Left Lane: Rickie Jones Runs 6.761/205.66, Now #11
Right Lane: Shane Gray Runs 6.668/207.27, Now #2
Shane just bumped his Dad back one spot going to the number two spot. Shane Gray's incremental times: 60ft-0.991 sec., 330ft-2.791, 660ft-4.290/164.35 mph, 1,000ft-5.580. Jones went to the final last week and I'm not sure he will be happy with this one. Rickie Jones' incremental times: 60ft-0.995 sec., 330ft-2.837, 660ft-4.359/162.45 mph, 1,000ft-5.664.
Left Lane: Rodger Brogdon Runs 6.648/207.59, Now #1
Right Lane: Ron Krisher Runs 6.654/207.91, Now #2
This is a great side-by-side drag race as these two go to the number one and two spots. Rodger Brogdon's incremental times: 60ft-0.993 sec., 330ft-2.784, 660ft-4.275/165.03 mph, 1,000ft-5.563.
Ron Krisher's incremental times: 60ft-0.993 sec., 330ft-2.806, 660ft-4.286/167.36 mph, 1,000ft-5.570.
Left Lane: Jason Line Runs 6.647/207.78, Now #1
Right Lane: Greg Stanfield Runs 6.669/206.67, Now #6
Stanfield with a nice pass to get in the top half of the show. Greg Stanfield's incremental times: 60ft-0.987 sec., 330ft-2.783, 660ft-4.283/164.23 mph, 1,000ft-5.577. Line launched hard and keep it hooked up to go to the number one spot. Jason Line's incremental times: 60ft-0.987 sec., 330ft-2.778, 660ft-4.272/164.87 mph, 1,000ft-5.561.
Left Lane: Greg Anderson Runs 13.571/44.90, Now #18
Right Lane: Jeg Coughlin Runs 6.658/208.20, Now #4
Anderson with problems right off the starting line and pushes in the clutch. Coughlin is straight down the groove with the fastest pass of the session, so far. Jeg Coughlin's incremental times: 60ft-0.997 sec., 330ft-2.799, 660ft-4.291/165.11 mph, 1,000ft-5.575.
Left Lane: Allen Johnson Runs 6.644/208.46, Now #2
Right Lane: Mike Edwards Runs 6.641/207.88, Now #1
This is a great drag race to wrap up round one with these two going to the number one and two spots. Allen Johnson's incremental times: 60ft-0.992 sec., 330ft-2.784, 660ft-4.276/165.07 mph, 1,000ft-5.562.
Mike Edwards' incremental times: 60ft-0.985 sec., 330ft-2.778, 660ft-4.270/165.03 mph, 1,000ft-5.556.
Timing data courtesy of CompuLink
From DRC.com
By Rick Green
From DRC.com
Round 2 Qualifying
Fri, 25 Jun 2010, 10:12 PM
Pro Stock Qualifying Notes, Session #2
By Rick Green
NORWALK, Ohio - Notes from round 2 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, Fourth annual Summit Racing Equipment NHRA Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Bob Benza No Time, Now #18; Best prior run: 6.750/204.17, Was #17
Right Lane: Kurt Johnson Runs 6.634/208.17, Now #1; Best prior run: 14.616/57.73, Was #22
Weather conditions: air temperature 76 degrees, relative humidity 47 percent, barometer 29.06 inches, adjusted altitude 2,679 feet, track temperature 96 degrees.
Benza with a big wheel stand and then the car got out of the groove. Then it darted across both lanes and hit the right wall with left front of the car and then spun around and slammed the driver side of the car. He then spun around and came to a stop in the middle of the track. Johnson in the other lane with a great pass and he goes to the number one spot. Kurt Johnson's incremental times: 60ft-0.988 sec., 330ft-2.777, 660ft-4.267/165.11 mph, 1,000ft-5.551.
Left Lane: Erica Enders Runs 6.663/206.39, Now #9; Best prior run: 6.730/204.91, Was #17
Right Lane: Jim Cunningham No Time, Now #22; Best prior run: 13.881/60.98, Was #22
Cunningham started drifting out of the groove and got over by the wall and tagged it. Enders was straight down the groove to get in the sho for now. Erica Enders' incremental times: 60ft-0.983 sec., 330ft-2.777, 660ft-4.276/164.29 mph, 1,000ft-5.572.
Left Lane: Vinnie Deceglie Runs 7.994/121.75, Now #17; Best prior run: 6.692/206.80, Was #16
Right Lane: Greg Anderson Runs 6.627/208.42, Now #1; Best prior run: 13.571/44.90, Was #21
Deceglie started drifting out of the groove and got real close to the centerline before he lifted. Anderson launched hard and was straight down the groove to go to the number one spot. Greg Anderson's incremental times: 60ft-0.992 sec., 330ft-2.776, 660ft-4.263/165.46 mph, 1,000ft-5.546.
Left Lane: Warren Johnson Runs 6.609/208.68, Now #1; Best prior run: 6.691/207.02, Was #16
Right Lane: John Gaydosh Jr Runs 6.843/200.35, Now #21; Best prior run: 6.902/199.49, Was #21
Gaydosh made big move in the right direction, but not enough to get in the show. Johnson with a great pass to go to the number one spot and sets both ends of track record. Warren Johnson's incremental times: 60ft-0.971 sec., 330ft-2.758, 660ft-4.245/165.42 mph, 1,000ft-5.529.
Left Lane: Johnny Gray Runs 6.623/208.23, Now #2; Best prior run: 6.677/207.56, Was #14
Right Lane: Rickie Jones Runs 6.636/206.80, Now #5; Best prior run: 6.761/205.66, Was #20
Gray with a nice pass to go to the number two spot. Johnny Gray's incremental times: 60ft-0.969 sec., 330ft-2.762, 660ft-4.254/165.21 mph, 1,000ft-5.540. Jones gets into the top half of the show...Rickie Jones' incremental times: 60ft-0.971 sec., 330ft-2.762, 660ft-4.257/164.57 mph, 1,000ft-5.548.
Left Lane: Greg Stanfield Runs 6.631/207.27, Now #4; Best prior run: 6.669/206.67, Was #15
Right Lane: Larry Morgan Runs 6.636/207.69, Now #6; Best prior run: 6.693/206.80, Was #19
A couple more straight down the groove and they both get into the top half of the show. Greg Stanfield's incremental times: 60ft-0.979 sec., 330ft-2.763, 660ft-4.255/164.85 mph, 1,000ft-5.545.
Larry Morgan's incremental times: 60ft-0.985 sec., 330ft-2.772, 660ft-4.264/165.29 mph, 1,000ft-5.551.
Left Lane: Shane Gray Runs 6.656/206.76, Now #14; Best prior run: 6.668/207.27, Was #16
Right Lane: Bob Yonke Runs 6.620/207.85, Now #2; Best prior run: 6.688/206.76, Was #18
Yonke with a real nice pass to go to the number two spot...Bob Yonke's incremental times: 60ft-0.979 sec., 330ft-2.760, 660ft-4.250/165.23 mph, 1,000ft-5.535. Gray improves, but he won't be happy with this pass in these weather conditions. Shane Gray's incremental times: 60ft-0.975 sec., 330ft-2.770, 660ft-4.267/163.69 mph, 1,000ft-5.567.
Left Lane: V. Gaines Runs 6.620/208.17, Now #2; Best prior run: 6.661/207.40, Was #16
Right Lane: Justin Humphreys Runs 6.659/206.76, Now #17; Best prior run: 6.686/206.67, Was #18
Humphreys improves but not enough to get in the show. Gaines with a great pass and he ties Yonke's E.T. and will get the number two spot because of the faster mph. V. Gaines' incremental times: 60ft-0.974 sec., 330ft-2.762, 660ft-4.253/165.07 mph, 1,000ft-5.538.
Left Lane: Jeg Coughlin Runs 6.592/208.97, Now #1; Best prior run: 6.658/208.20, Was #16
Right Lane: Rodger Brogdon Runs 9.592/96.07, Now #14; Best prior run: 6.648/207.59, Was #13
Brogdon got loose and out of the groove and over by the centerline before he clicked it off. Coughlin launched hard and was straight down the groove to the number one spot with both ends of the track record. Jeg Coughlin's incremental times: 60ft-0.976 sec., 330ft-2.753, 660ft-4.236/165.99 mph, 1,000ft-5.514.
Rodger Brogdon's incremental times: 60ft-0.985 sec., 330ft-2.887, 660ft-5.047/102.77 mph, 1,000ft-7.351.
Left Lane: Ron Krisher Runs 6.602/209.17, Now #2; Best prior run: 6.654/207.91, Was #15
Right Lane: Jason Line Runs 6.620/208.62, Now #4; Best prior run: 6.647/207.78, Was #13
Line ties Gaines and Yonke's E.T. and he gets the number four spot because he has the faster speed. Jason Line's incremental times: 60ft-0.983 sec., 330ft-2.770, 660ft-4.258/165.56 mph, 1,000ft-5.540. Krisher with a great pass to go to the number two spot and he gets the track speed record. Ron Krisher's incremental times: 60ft-0.971 sec., 330ft-2.769, 660ft-4.256/163.45 mph, 1,000ft-5.524.
Left Lane: Mike Edwards Runs 13.060/60.74, Now #14; Best prior run: 6.641/207.88, Was #13
Right Lane: Allen Johnson Runs 6.602/209.30, Now #2; Best prior run: 6.644/208.46, Was #14
Edwards shook right off the starting line and clicked it off. Johnson with a great pass to go to the number two spot. He sets the track speed record. Allen Johnson's incremental times: 60ft-0.979 sec., 330ft-2.759, 660ft-4.245/165.78 mph, 1,000ft-5.524.
From DRC.com
By Rick Green
From DRC.com
Round 3 Qualifying
Sat, 26 Jun 2010, 12:50 PM
Pro Stock Qualifying, Session #3 Order
NORWALK, Ohio - Order after 3 rounds of qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, Fourth annual Summit Racing Equipment NHRA Nationals:
Psn---Num-Driver, Home Town, Car Type---------------Qual-ET--Qual-Spd-Top Spd
1 50 Jeg Coughlin, Delaware OH, '10 Cobalt 6.592 208.97 208.97
2 7 Allen Johnson, Greeneville TN, '10 Avenger 6.602 209.30 209.30
3 6 Ron Krisher, Warren OH, '10 Cobalt 6.602 209.17 209.17
4 208 Warren Johnson, Sugar Hill GA, '09 GXP 6.609 208.68 208.68
5 3 Jason Line, Mooresville NC, '09 GXP 6.620 208.62 208.62
6 55 V. Gaines, Lakewood CO, '10 Avenger 6.620 208.17 208.17
7 406 Bob Yonke, Burleson TX, '09 GXP 6.620 207.85 207.85
8 9 Johnny Gray, Artesia NM, '09 GXP 6.623 208.23 208.23
9 2 Greg Anderson, Morresville NC, '09 GXP 6.627 208.42 208.42
10 4 Greg Stanfield, Bossier City LA, '09 GXP 6.631 207.27 207.27
11 8 Kurt Johnson, Sugar Hill GA, '10 Cobalt 6.634 208.17 208.17
12 1 Mike Edwards, Coweta OK, '09 GXP 6.634 208.01 208.01
13 357 Larry Morgan, Newark OH, '10 Mustang 6.636 207.69 207.69
14 41 Rodger Brogdon, Tomball TX, '09 GXP 6.667 206.67 207.59
15 730 Shane Gray, Denver NM, '09 GXP 6.669 206.01 207.27
16 32 Justin Humphreys, Monrovia MD, '09 GXP 6.679 205.98 206.76
------------ Not Qualified ------------
17 10 Rickie Jones, Galesburg IL, '10 GXP 6.683 206.04 206.80
18 7406 Vinnie Deceglie, Rancho Cucamonga CA, '10 Aven 6.690 207.40 207.40
19 430 Erica Enders, New Orleans LA, '10 Mustang 6.701 205.76 206.39
20 109 Jim Cunningham, Crownsville MD, '10 Mustang 6.750 203.92 203.92
21 128 John Gaydosh Jr, Baltimore MD, '07 GTO 6.932 198.80 200.35
22 136 Bob Benza, Briarcliff Manor NY, '10 GXP NT
From DRC.com
From DRC.com
Sat, 26 Jun 2010, 06:10 PM
Pro Stock Qualifying, Final Order
NORWALK, Ohio - Final order after 4 rounds of qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, Fourth annual Summit Racing Equipment NHRA Nationals:
20 109 Jim Cunningham, Crownsville MD, '10 Mustang 6.750 203.92 203.92 21 128 John Gaydosh Jr, Baltimore MD, '07 GTO 6.932 198.80 200.35
From DRC.com
From DRC.com
Round 1 Eliminations
Sun, 27 Jun 2010, 12:36 PM
Pro Stock Round 1 Eliminations
By Rick Green
NORWALK, Ohio - Results of round 1 eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, Fourth annual Summit Racing Equipment NHRA Nationals:
Car#-Driver(Opp'nt)-RT-----ET---Speed-----Car#-Driver(Opp'nt)-RT----ET---Speed
2 Greg Anderson (W)......vs.........9 Johnny Gray
0.027 6.698 205.54 ........................ 0.014 6.727 205.63
Weather conditions: air temperature 85 degrees, relative humidity 62 percent, barometer 28.84 inches, adjusted altitude 3,951 feet, track temperature 114 degrees.
Gray with the starting line advantage, but Anderson has the difference made up by 150 feet and takes the win by 0.0165 seconds (approximately 5 feet).
4 Greg Stanfield (W)......vs......406 Bob Yonke
0.044 6.725 205.16 ..............0.049 7.211 152.33
Yonke is 1 - 0 against Stanfield in prior events. They leave together and then it is all Stanfield for the win, Yonke has problems and slows.
8 Kurt Johnson .......vs.............55 V. Gaines (W)
0.061 6.730 205.91 ................ 0.032 6.725 205.04
Johnson is 18 - 5 against Gaines in prior events. Gaines with the starting line advantage and the win by 0.0345 seconds (approximately 10 feet).
1 Mike Edwards .........................vs...................3 Jason Line (W)
.032 6.703 206.29 .................... 0.026 6.704 205.85
Line is out of the gate first and has the power to hold on for the hole shot win... Jason Line's MOV: 0.0057 seconds (approximately 21 inches).
357 Larry Morgan(W) .........................vs..........208 Warren Johnson 0.038 6.736 205.01 ...................0.073 6.708 206.01
Johnson is 37 - 19 against Morgan in prior events. Morgan with the starting line advantage and the power to hold on for the hole shot win. Larry Morgan's MOV: 0.0079 seconds (approximately 2 feet). Morgan will give up lane choice to Line in the next round.
41 Rodger Brogdon ........................vs.......6 Ron Krisher (W)
0.077 6.697 205.57 .................... 0.063 6.710 205.04
Brogdon and Krisher have each won 3 times against the other in prior events. Krisher with the starting line advantage and the power to hold on for the hole shot win. Ron Krisher's MOV: 0.0013 seconds (approximately 5 inches). Brogdon with low E.T. of the round in the losing effort.
730 Shane Gray ........vs......7 Allen Johnson (W)
0.045 6.742 205.47 ................ 0.067 6.718 206.16
Johnson is 1 - 0 against Gray in prior events. Gray is out of the gate first and has the lead until right before the finish line when Johnson chased him down. Allen Johnson takes the win 0.0023 seconds (approximately 8 inches). Johnson will have lane choice over Stanfield in the next round.
32 Justin Humphreys .......vs............50 Jeg Coughlin (W)
.046 6.745 204.51 ......................... 0.063 6.722 205.41
Coughlin is 8 - 2 against Humphreys in prior events. Humphreys with the starting line advantage and then lead until just past 1000 feet when coughlin chased him down. Jeg Coughlin's MOV: 0.0063 seconds (approximately 23 inches). Coughlin will give up lane choice to Anderson in the next round.
From DRC.com
By Rick Green
From DRC.com
Round 2 Eliminations
Sun, 27 Jun 2010, 01:46 PM
Pro Stock Round 2 Eliminations
By Rick Green
NORWALK, Ohio - Results of round 2 eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, Fourth annual Summit Racing Equipment NHRA Nationals:
4 Greg Stanfield ......vs........7 Allen Johnson (W)
0.046 6.802 202.18 ........... 0.065 6.734 205.69
Johnson is 8 - 3 against Stanfield in prior events. They both take their time staging after turning on the pre-stage lights...Johnson goes in first and then Stanfield is out of the gate first and then lead until about 400 feet. Johnson chased him down and takes the win by 0.0491 seconds (approximately 15 feet).
55 V. Gaines (W) ......vs...........6 Ron Krisher
0.081 6.816 204.79 .....................0.207 6.710 205.91
Krisher is 7 - 5 against Gaines in prior events. Gaines with a big starting line advantage and the power to hold on for the hole shot win. V. Gaines' MOV: 0.0208 seconds (approximately 6 feet). Gaines will give up lane choice to Johnson in the semifinal.
357 Larry Morgan .....vs........3 Jason Line (W)
0.049 6.762 205.32 ........... 0.046 6.711 205.13
Line is 11 - 6 against Morgan in prior events. Line with a slight starting line advantage and never trailed in this race. Jason Line's MOV: 0.0548 seconds (approximately 17 feet). Line with the low E.T. of the round. Jason Line's incremental times: 60ft-0.993 sec., 330ft-2.800, 660ft-4.308/163.14 mph, 1,000ft-5.612.
50 Jeg Coughlin .......vs..............2 Greg Anderson (W)
0.029 6.749 205.38 ..................... 0.049 6.713 204.85
Anderson is 35 - 25 against Coughlin in prior events. Coughlin is out of the gate first, but Anderson has him chased down by 150 feet and holds on for the win. Greg Anderson's MOV: 0.0169 seconds (approximately 5 feet). Anderson will give up lane choice to Line in the semifinal. Anderson keeps his chase to double up alive.
From DRC.com
By Rick Green
From DRC.com
Round 3 Eliminations
Sun, 27 Jun 2010, 03:04 PM
Pro Stock Round 3 Eliminations
By Rick Green
NORWALK, Ohio - Results of round 3 eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, Fourth annual Summit Racing Equipment NHRA Nationals:
55 V. Gaines ..........vs........7 Allen Johnson (W)
0.054 6.976 204.05 ...............0.103 6.740 206.01
Weather conditions: air temperature 87 degrees, relative humidity 66 percent, barometer 28.72 inches, adjusted altitude 4,314 feet, track temperature 128 degrees.
Johnson is 10 - 6 against Gaines in prior events. Gaines with the starting line advantage, but then has problems right off the starting line. Johnson is straight down the groove until right in the lights when he got real loose, but holds on for the win.
2 Greg Anderson (W).................vs...............3 Jason Line
0.041 6.723 204.88 .......................0.062 6.718 205.57
Anderson is 18 - 13 against Line in prior events. Anderson is out of the gate first and has the power to hold on for the hole shot win. Greg Anderson's MOV: 0.0162 seconds (approximately 5 feet). Anderson will have lane choice over Johnson in the final.
From DRC.com
By Rick Green
From DRC.com
Finals
Sun, 27 Jun 2010, 04:12 PM
Pro Stock Final, Round 4 Eliminations
By Rick Green
NORWALK, Ohio - Results of final, round 4 eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, Fourth annual Summit Racing Equipment NHRA Nationals:
7 Allen Johnson..........vs.......... 2 Greg Anderson (W)
0.036 6.982 159.38 ................... 0.021 6.722 204.54
Weather conditions: air temperature 88 degrees, relative humidity 56 percent, barometer 28.70 inches, adjusted altitude 4,269 feet, track temperature 119 degrees.
Anderson is 27 - 9 against Johnson in prior events and each has won 1 times against the other in final rounds. Anderson with the starting line advantage and then just drives away for the win. Johnson got out of the groove and over by the centerline before he pushed in the clutch. Anderson collect 61st Wally and his first this year. Anderson will also collect the double-up bonus for the second time in his career.
From DRC.com
By Rick Green
From DRC.com
