Las Vegas Nationals
Las Vegas Nationals
Friday
Results for Qualifying Round 1
LAS VEGAS - LAS VEGAS 2 - Notes from round 1 qualifying in Funny Car at the NHRA Full Throttle Drag Racing Series, Ninth annual NHRA Las Vegas Nationals
listing lane, driver name, elapsed time, top speed, and position in order following run:
Left Lane: Jeff Diehl Runs 4.439/221.13, Now #12:27 p.m. Weather conditions: air temperature 74 degrees, relative humidity 22 percent, barometer 28.00 inches, adjusted altitude 3,568 feet, track temperature 92 degrees. Diehl was on a decent pass then the car nosed over about 800 feet out.
Left Lane: Grant Downing Runs 4.323/245.32, Now #1
Right Lane: Bob Bode Runs 5.621/126.74, Now #3
Bode gets about 300 feet out, strikes the tires, then backs off the throttle. No problems for Downing, right down the middle of the lane.
Left Lane: Gary Densham Runs 5.273/139.86, Now #3
Right Lane: Jim Head No Time, Now #5
Densham gets about 300 feet out, strikes the tires, then clicks it off. Head gets out of the groove about 300 feet out then makes a hard move to the left and takes out the 330 foot timing block.
Left Lane: Jerry Toliver Runs 5.405/118.03, Now #4
Right Lane: Jeff Arend Runs 7.608/87.49, Now #6
Arend gets about 300 feet out and strikes the tires; Toliver just a little further than goes up in smoke.
Left Lane: Matt Hagan Runs 4.134/306.12, Now #1
Right Lane: Cruz Pedregon Runs 7.281/82.72, Now #7
Pedregon gets about 200 feet out and goes up in smoke. hagan makes a tremendous run, right down the groove, not a hint of tire smoke and he takes the early pole.
Left Lane: Mike Neff Runs 4.184/299.66, Now #2
Right Lane: John Force Runs 4.185/302.28, Now #3
A good side by side, Neff and Force were glued together all the way through the run.
Left Lane: Del Worsham Runs 4.155/306.12, Now #3
Right Lane: Bob Tasca III Runs 4.136/307.02, Now #2
A couple of good passes, both go right down the groove and get in the second and third spots.
Left Lane: Jack Beckman Runs 4.121/305.01, Now #1
Right Lane: Tim Wilkerson Runs 4.163/292.77, Now #5
Beckman goes right down the groove and takes the top spot for now. Wilkerson makes a decent pass.
Left Lane: Ron Capps Runs 5.578/126.09, Now #13
Right Lane: Tony Pedregon Runs 4.133/304.74, Now #2
Capps gets about 300 feet out, strikes the tires, then backs off the throttle. Pedregon makes a good pass to get in the second spot for now.
Left Lane: A. Force Hood Runs 4.163/303.23, Now #7
Right Lane: Robert Hight Runs 4.090/305.42, Now #1
Force-Hood was moving around all the way through the run, first making a quick move to the right, then back to the left, but she never backs off the throttle and makes a decent pass. hight makes a very impressive run, right down the groove, and he takes the top spot and picks up the three bonus points.
Round Two of Qualifying
Friday
Order for Qualifying Round 2
LAS VEGAS - SUMMIT FastNews - Order after 2 rounds of qualifying in Funny Car at the NHRA Full Throttle Drag Racing Series, Ninth annual NHRA Las Vegas Nationals:
Psn Driver Vehicle ET Speed
1. Matt Hagan Fram/Shelor Charger 4.030@ 313.88&
2. Ron Capps NAPA Auto Parts Charger 4.041 310.55
3. Robert Hight AAA of So. Cal Mustang 4.065 308.71
4. Tony Pedregon Quaker State Impala 4.098 309.20
5. Bob Tasca III Motorcraft/Quick Lane Mustang 4.107 307.02
6. Cruz Pedregon Advance Auto Parts Solara 4.114 305.98
7. Tim Wilkerson Levi, Ray & Shoup Mustang 4.116 297.22
8. Jack Beckman Valvoline/MTS Charger 4.118 305.01
9. Mike Neff JFR/Ford Mustang 4.128 302.62
10. Jim Head Head Racing Solara 4.132 305.84
11. John Force Castrol GTX Mustang 4.144 302.28
12. Del Worsham Al-Anabi Racing Solara 4.155 306.12
--------- Not Qualified ---------
13. Ashley Force Hood Castrol GTX Mustang 4.163 303.23
14. Gary Densham Impala 4.167 290.76
15. Jerry Toliver Canidae Pet Food Impala 4.241 279.15
16. Grant Downing Need2Speed Monte Carlo 4.323 245.32
17. Jeff Diehl Nitroagogo.com Monte Carlo 4.439 221.13
18. Bob Bode Alard Machine Products Impala 5.621 126.74
19. Jeff Arend DHL Solara 7.608 87.49
@ = Track ET Record
@ = Track ET Record
Round Three Qualifying
Saturday
Results for Qualifying Round 3
LAS VEGAS - LAS VEGAS 2 - Notes from round 3 qualifying in Funny Car at the NHRA Full Throttle Drag Racing Series, Ninth annual NHRA Las Vegas Nationals
listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Right Lane: Grant Downing Runs 13.245/65.07, Now #16 Best prior run: 4.323/245.32, Was #16
1:38 p.m. Weather conditions: air temperature 75 degrees, relative humidity 24 percent, barometer 28.02 inches, adjusted altitude 3,721 feet, track temperature 98 degrees.
Downing goes up in smoke as soon as he hits the throttle.
Right Lane: Grant Downing Runs 13.245/65.07, Now #13 No Prior Run
1:42 p.m. Weather conditions: air temperature 75 degrees, relative humidity 24 percent, barometer 28.02 inches, adjusted altitude 3,721 feet, track temperature 98 degrees.
Left Lane: Jeff Arend Runs 5.423/133.38, Now #14 No Prior Run
Right Lane: Jeff Diehl Runs 4.254/291.89, Now #13 No Prior Run
Arend gets about 400 feet out, strikes the tires and backs off the throttle. He will get in the show for now in the 14th spot. Diehl makes a clean pass and gets in at the 13th spot for now.
Left Lane: Bob Bode Runs 4.281/262.85, Now #14 No Prior Run
Right Lane: Del Worsham Runs 4.947/157.69, Now #12 Best prior run: 4.155/306.12, Was #12
Worsham was on a decent pass but hazed the tires about 600 feet out and backed off the throttle. Bode makes a decent pass but put out a little smoke as he went through the lights.
Left Lane: John Force Runs 4.362/275.34, Now #11 Best prior run: 4.144/293.09, Was #11
Right Lane: Jerry Toliver Runs 7.074/94.22, Now #16 No Prior Run
Toliver gets about 400 feet out, hazes the tires and backs off the throttle but he gets in on the bump for now. Force was on a decent run, then hazes the tires, pedals, starts moving around all over the track, but stays on the throttle.
Left Lane: Jim Head Runs 4.168/290.82, Now #10 Best prior run: 4.132/305.84, Was #10
Right Lane: A. Force Hood Runs 4.269/289.38, Now #14 No Prior Run
Force-Hood had a cylinder out all the way through the run but she runs well enough to get in the show for now. Head makes a clean, straight pass but doesn't improve.
Left Lane: Tim Wilkerson Runs 4.628/181.18, Now #7 Best prior run: 4.116/297.22, Was #7
Right Lane: Gary Densham Runs 4.197/288.64, Now #13 No Prior Run
Densham makes a nice, clean run here and gets in the show in the 13th spot for now. Wilkerson was out in front of Densham until the 660 foot mark, then he hazes the tires, starts to get out of shape, then backs off the throttle.
Left Lane: Cruz Pedregon Runs 4.161/305.36, Now #6 Best prior run: 4.114/305.98, Was #6
Right Lane: Mike Neff Runs 6.261/103.01, Now #9 Best prior run: 4.128/302.62, Was #9
Neff gets about 20 feet out, strikes the tires, then gives up on the run. Pedregon goes right down the groove with the quickest pass of the round so far.
Left Lane: Bob Tasca III Runs 4.932/160.82, Now #5 Best prior run: 4.107/307.02, Was #5
Right Lane: Jack Beckman Runs 4.171/298.80, Now #8 Best prior run: 4.118/304.87, Was #8
Beckman makes a decent pass, the third quickest of the round so far, but he doesn't improve. Tasca was a little ahead of Beckman at the 330, then starts hazing the tires about 500 feet out and has to give up on the run.
Left Lane: Tony Pedregon Runs 4.182/301.81, Now #4 Best prior run: 4.098/309.20, Was #4
Right Lane: Ron Capps Runs 5.934/111.35, Now #2 Best prior run: 4.041/310.55, Was #2
Capps gets about 300 feet out and goes up in smoke. pedregon makes a decent pass for the conditions but doesn't improve.
Left Lane: Robert Hight Runs 5.376/134.79, Now #3 Best prior run: 4.065/308.71, Was #3
Right Lane: Matt Hagan Runs 4.153/305.08, Now #1 Best prior run: 4.030/313.88, Was #1
Hight gets about 400 feet out and strikes the tires. Hagan makes another nice pass but doesn't improve.
Hagan, Cruz Pedregon and Head pick up the bonus points this round.
Round Four of Qualifying
Saturday
Order for Qualifying Round 4
LAS VEGAS - SUMMIT FastNews - Final order after 4 rounds of qualifying in Funny Car at the NHRA Full Throttle Drag Racing Series, Ninth annual NHRA Las Vegas Nationals:
1. Matt Hagan Fram/Shelor Charger 4.030 313.88
13. Jeff Arend DHL Solara 4.167 302.69
14. Ashley Force Hood Castrol GTX Mustang 4.197 303.23
15. Gary Densham Impala 4.197 290.76
16. Grant Downing Need2Speed Monte Carlo 4.211 291.89
17. Jeff Diehl Nitroagogo.com Monte Carlo 4.224 296.70
18. Bob Bode Alard Machine Products Impala 4.281 262.85
19. Jerry Toliver Canidae Pet Food Impala 7.074 279.15
Round 1 Eliminations
Sunday
Results for Elimination Round 1
LAS VEGAS - SUMMIT FastNews - Results of round 1 eliminations in Funny Car at the NHRA Full Throttle Drag Racing Series, Ninth annual NHRA Las Vegas Nationals:
W/L Driver R-Time E-Time Speed
(W) Tim Wilkerson (Levi, Ray & Shoup Mustang) 0.084 4.159 299.00
(L) Jim Head (Head Racing Solara) 0.134 4.146 307.44
11:37 a.m. Weather conditions: air temperature 76 degrees, relative humidity 24 percent, barometer 28.00 inches, adjusted altitude 3,781 feet, track temperature 96 degrees.
Head holds a 3-1 advantage in head to head career match-ups with Wilkerson, 1-1 in the first round.
Wilkerson gets a big advantage off the line, then Head starts to make up ground after half-track but runs out room.
(W) Del Worsham (Al-Anabi Racing Solara) 0.066 4.163 304.19
(L) Bob Tasca III (Motorcraft/Quick Lane Mustan 0.079 5.057 162.63
Tasca and Worsham have faced each other four times, all in round one, and have split the matches.
Tasca comes off the line, gets about 400 feet out and goes up in smoke. Worsham goes right down the groove with a decent pass to take the win.
(W) Matt Hagan (Fram/Shelor Charger) 0.097 4.131 303.50
(L) Grant Downing (Need2Speed Monte Carlo) 0.103 4.244 284.21
These two have met only once before, in Denver earlier this year with Hagan winning that one. This is the second time Hagan has qualified number one.
Not much difference off the line for these two, then Hagan starts to slowly pull away. He continues to extend his lead all the way through the run and makes the quickest pass of the round so far for the win.
(W) Ron Capps (NAPA Auto Parts Charger) 0.106 4.130 305.08
(L) Gary Densham (Impala) 0.110 4.208 292.52
These two have met 28 times in their careers with Capps winning 19 of those. He also holds a 10-5 advantage in first round match-ups.
Capps gets a small advantage off the line and slowly extends his lead all the way through the run. Densham made a decent pass but couldn't keep up with Capps.
(W) Robert Hight (AAA of So. Cal Mustang) 0.071 4.114 309.06
(L) Ashley Force Hood (Castrol GTX Mustang) 0.068 4.338 283.37
Hight holds a 5-3 advantage over Force-Hood in career natch-ups, 3-1 when they have met in the first round. They are currently first and second in the points with Hight holding a 25 point advantage
This one was close coming off the line but then it was all Hight. He starts pulling away slowly then quickly pulled away on the top end to take this important win.
Robert Hight's incremental margins (negative if behind): 60ft(0.031), 330 ft(0.085), 660ft(0.152). MOV: 0.2215 seconds (approximately 92 feet).
(W) Tony Pedregon (Quaker State Impala) 0.091 4.271 283.85
(L) Jeff Arend (DHL Solara) 0.054 4.331 280.89
Arend and Pedregon have met ten times with Pedregon winning six of those. He also holds a 5-2 advantage in first round match-ups.
Arend gets out of the gate first and hangs on to the lead to the 330 foot mark. Pedregon pulls even, then slowly starts to pull away. Pedregon loses a cylinder but is able to continue extending his lead and takes the win to keep pace with Hight.
Tony Pedregon's incremental margins (negative if behind): 60ft(-0.055), 330 ft(0.000), 660ft(0.016). MOV: 0.0231 seconds (approximately 10 feet).
(W) John Force (Castrol GTX Mustang) 0.050 4.662 220.80
(L) Cruz Pedregon (Advance Auto Parts Solara) 0.047 4.855 230.57
Force and Pedregon have met many times before with Force holding the advantage 53-25. Surprisingly, they have only met once this year with Force winning that one. the winner of this race will race Hight in the next round.
They come off the line together and Pedregon holds the early lead. pedregon gets about 200 feet and strikes the tires. Force gets a little further, about 400 feet out and they both start to pedal. Force has a little more momentum, is able to recover quicker, and goes on for the win.
John Force's incremental margins (negative if behind): 60ft(-0.008), 330 ft(0.199), 660ft(0.287). MOV: 0.1903 seconds (approximately 64 feet).
(W) Jack Beckman (Valvoline/MTS Charger) 0.097 4.430 261.12
(L) Mike Neff
Another pedaling contest, Neff gets the early advantage then strikes the tires about 200 feet out. Beckman gets about 400 feet out, loses traction and starts to pedal. Both recover but Beckman was way out in front and held on to take the win.
Jack Beckman's incremental margins (negative if behind): 60ft(-0.024), 330 ft(-0.022), 660ft(0.081). MOV: 0.2602 seconds (approximately 76 feet)
. In the next round it will be Hagan with lane choice over Beckman, Worsham vs. Tony Pedregon, Capps vs. Wilkerson, and Hight vs. Force.
(L) Mike Neff
Round 2 Eliminations
Sunday
Results for Elimination Round 2
LAS VEGAS - SUMMIT FastNews - Results of round 2 eliminations in Funny Car at the NHRA Full Throttle Drag Racing Series, Ninth annual NHRA Las Vegas Nationals:
(W) Jack Beckman (Valvoline/MTS Charger) 0.097 4.210 285.41
(L) Matt Hagan (Fram/Shelor Charger) 0.092 4.242 287.35
1:33 p.m. Weather conditions: air temperature 79 degrees, relative humidity 21 percent, barometer 27.92 inches, adjusted altitude 3,988 feet, track temperature 97 degrees.
They came off the line together and Hagan put a cylinder out on the left side. He started drifting to the left but was able to hold it off the center line. Beckman got to half track, put out a cylinder on the left side and started drifting to the left. He goes through the lights, gets very close to the wall after the finsih line, but somehow beckman holds it off.
Jack Beckman's incremental margins (negative if behind): 60ft(0.000), 330 ft(0.018), 660ft(0.027). MOV: 0.0272 seconds (approximately 11 feet).
(W) Tim Wilkerson (Levi, Ray & Shoup Mustang) 0.096 4.163 301.40
(L) Ron Capps (NAPA Auto Parts Charger) 0.104 4.157 303.78
This was a great side by side race, both going right down the groove, candles lit all the way through the run. Wilkerson gets off the line just a little ahead of Capps, then Capps closes the gap at half track. He continues reel in Wilkerson but runs out of race track.
(W) Robert Hight (AAA of So. Cal Mustang) 0.118 4.125 309.42
(L) John Force (Castrol GTX Mustang) 0.119 5.723 142.19
Force and Hight leave the line together then Force strikes the tires about 300 feet out. He pedals, starts skating around, then crosses the center line a little past the 660 foot mark. Hight goes right down the groove with the second quickest run of eliminations.
(W) Del Worsham (Al-Anabi Racing Solara) 0.030 4.232 269.67
(L) Tony Pedregon (Quaker State Impala) 0.086 4.176 303.64
Worsham gets a huge hole shot and starts to pull away, extending his lead to the 330 foot mark. Pedregon starts to reel him in at that point and closes the gap but comes up a litlle short.
Del Worsham's incremental margins: 60ft(0.069), 330 ft(0.077), 660ft(0.074). MOV: 0.0004 seconds (approximately 2 inches).
Round 3 Eliminations
Sunday
Results for Elimination Round 3
LAS VEGAS - SUMMIT FastNews - Results of round 3 eliminations in Funny Car at the NHRA Full Throttle Drag Racing Series, Ninth annual NHRA Las Vegas Nationals:
(W) Jack Beckman (Valvoline/MTS Charger) 0.083 4.359 262.90
(L) Del Worsham (Al-Anabi Racing Solara) 0.006 8.613 77.85
3:24 p.m. Weather conditions: air temperature 84 degrees, relative humidity 21 percent, barometer 27.90 inches, adjusted altitude 4,392 feet, track temperature 89 degrees. Beckman has an 8-1 advantage in match-ups with Worsham, 2-0 this year. Worsham hits the throttle, goes up in smoke and has to back off the throttle. Beckman was on a decent run but started mixing up cylinders late in the run.
(W) Robert Hight (AAA of So. Cal Mustang) 0.095 4.080 312.57
(L) Tim Wilkerson (Levi, Ray & Shoup Mustang) 0.088 4.233 285.41
Wilkerson gets off the line a little ahead of hight but that was about all. Hight drives around him quickly then goes right down the groove to pull away for the win and another 20 points added to his lead. The 312.57 speed for Hight is the second fastest in history for 1000 feet. Hight will have lane choice over Beckman in the final round.
Finals
Sunday
Results for Final Round
LAS VEGAS - SUMMIT FastNews - Results of final, round 4 eliminations in Funny Car at the NHRA Full Throttle Drag Racing Series, Ninth annual NHRA Las Vegas Nationals:
(W) Robert Hight (AAA of So. Cal Mustang) 0.075 4.125 304.46
(L) Jack Beckman (Valvoline/MTS Charger) 0.058 4.154 303.16
5:14 p.m. Beckman is 8-8 in final in final rounds, 2-2 this year. This is his second final round at this track. He won this event in 2006.
Hight is 13-12 in final rounds, 2-1 this year. He beat Beckman in one final round in Dallas earlier this year. Hight has the three quickest times in eliminations today.
Beckman gets out of the gate first and hangs on to the lead until just past the 330 foot mark. Hight was making up ground quickly and drove around him at that point. Hight kept the candles lit all the way through the run and pulled away for the win.
With this win Hight will have a 105 point lead over his team-mate Force-Hood going into the last race. Robert Hight's incremental margins (negative if behind): 60ft(-0.024), 330 ft(-0.017), 660ft(0.004). MOV: 0.0127 seconds (approximately 6 feet).
