Mopar Forums (/forums/)
-   Do-It-yourself Section (https://moparforums.com/forums/f6/)
-   -   318 question (https://moparforums.com/forums/f6/318-question-22258/)
Mike68 Apr 23, 2019 12:01 PM
318 question
I have a 1981 Dodge W150. It has a 2 barrel intake, if I get a 4 barrel adapter and 4 barrel carburetor would it make a difference?
Iowan Apr 23, 2019 01:36 PM
Save your money......
RacerHog Apr 23, 2019 02:05 PM
Better to get the rite manifold and the correct linkage..... I agree... Save your money.
Archer Apr 24, 2019 06:11 AM
Mike -
Well, maybe...
Will it make any real difference, maybe a little, and if you don't have a lead foot, you'll get better mileage, assuming you pick the right size carb, of course.
The real reason to do that,would be because bucks are tight, and you can start with the carb and get the manifold a little later, but again, lets be real, 318 manifolds aren't that expensive, especially if you look at the used market.
Unfortunately, the carb/manifold swap is only the first step, then headers, cam, etc.
Iowan Apr 24, 2019 08:03 AM
Save your money
Sammyes1998 Apr 28, 2019 03:11 PM
Since yall are talking about carbs. My brother in law has an 83 318 with electric choke but the electric part doesnt work, is there a way to rig it to make it manual?
RacerHog Apr 28, 2019 05:20 PM
carb mfg. mite have a conversation kit check with them. Because I have no idea what carb you have at this time.
Sammyes1998 Apr 28, 2019 06:20 PM
Sorry, its a 2 barrel
RacerHog Apr 29, 2019 05:48 AM
Check the power to the choke thermostat. If it's not getting voltage, then the resister may be bad and need replacing.
Sammyes1998 Apr 29, 2019 05:51 AM
Getting 0 voltage. Ill go ahead and see if an autoparts store has one when i get off work later
RacerHog Apr 29, 2019 06:03 AM
Before you buy one... Make sure you have voltage/power to the timer first. Might not be hooked up for some reason? Or maybe the feed/power wire is broken?
