61 Fury Brakes Seizing when warmed up
My brakes work when cold but when hot they seize or lock up on the right front when I apply the brake pedal. The wheel locks up and the tire screeches and the pedal does not return to normal position without pulling it up. The brakes have 4 stock drums and the stock single master cylinder. Shoes are brand new. Not sure if it is a return spring or drum, or something entirely. Any ideas?
Thank you for the input so far. I will check out the brake hose and the wheel cylinder.
I will try to get a picture up later. My car is a white convertible with a white and turquoise interior.
